Help with valve selection for rear remotes
/ Help with valve selection for rear remotes #1
nrguenth
Lewiston, WI
MF202, GC1720
I have a MF GC1720 and want to add 4 remotes to the back. I'd like to do 2 with float for top and tilt, and 2 standard DA for all the usual stuff. The only setup I've been able to find is the Prince 9SV-4-Y from Surplus Center that everyone seems to use. My problem is that this thing is HUGE. It's rated for 3 times what my pump will put out, and expensive, and is physically too big given that space is already at a premium on the back of my tractor. Does anyone know of a smaller 4 spool, 2x float, rated for ~5gpm valve setup I should be looking at? Thanks!
/ Help with valve selection for rear remotes #2
This valve is a 20 GPM stack valve.
It is going to be hard to find a 4 spool valve with the requirements you want.
You might be able to find a monoblock spool valve and add float to two of the spools.
4 SPOOL 20 SERIES PRINCE STACK VALVE OPEN CENTER
Item Number: 9-20-4-X
20 SERIES INLET SECTION W/2200-3000 PSI RELIEFQty: 1
20 SERIES OUTLET SECTION W/CONVERSION PLUGQty: 1
20 SERIES 4 SECTION BOLT KITQty: 1
20 SERIES DA WORK SECTION SPRING CENTEREDQty: 1
20 SERIES DA WORK SECTION W/DETENTED FLOATQty: 1
2 In Stock
$763.75
Perhaps this monoblock valve with 4 spools and add float to them. $275
4 SPOOL 8 GPM PRINCE MB41BBBB5C1 DA VALVE
Call Prince and see if there are float parts for this spool valve.
/ Help with valve selection for rear remotes #3
Contact Brian at FitRite Hydraulics, he can quote you a Bucher stack valve setup. It's still going to be big though, real estate will be a premium on the back of your small machine.
/ Help with valve selection for rear remotes #4
I can get you 12 GPM valves made up as you are looking for. Take a look here to see how I do 1000 series JD machines. We can probably do something similar to this for your tractor. ;)
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
2011 Bobcat E80 (A64126)
2011 Bobcat E80...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
