Loader JD955/70 loader
/ JD955/70 loader #1
LFH8541
Bradford NH
JD 955
I took my model 70 loader off so I could replace my water pump. came off like a breeze, so simple. I replaced it today and hooked up the hoses as I thought it was,
nope I am wrong. Can anyone tell me the right configuration. I have green, yellow, silver, and unmarked. Help
/ JD955/70 loader #2
Unmarked is black.
Put black and green to lift the loader, and yellow and silver to the bucket curl.
/ JD955/70 loader
Thank!!! I switched green and black and everything works just fine. I'm going to put colored wire ties on so this wont happen again, I've decided I like mowing
without the loader on. Thanks again.
/ JD955/70 loader #4
I have zip ties on each hose equating to whatever number it is.
If I had a quick attach bucket, I might leave the loader on while mowing. Since I don't, I almost always take it off. Much easier to maneuver around trees and such. Or between them when using the 4ft rotary.
/ JD955/70 loader #6
The zip tie trick is nice. Especially once I figured out the ports on the tractor are numbered 1-4 from left to right. I was taking the loader off to mow but now that I've converted to SSQA I find it easier to just drop the bucket. Still not as nice as removing the loader of course.
/ JD955/70 loader #7
I'm not sure which I'll do once I get a SSQA. I think I'll try it both ways and go from there. Since my mower is a 72" MMM, attaching/removing it is harder than mounting the loader.
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
49"X79" EXPANDED METAL TAILGATE (A62130)
49"X79" EXPANDED...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2023 Ferris 500S Zero Turn Mower (A61166)
2023 Ferris 500S...
2018 GENERAC MAGNUM 25 GENERATOR (A62129)
2018 GENERAC...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A63118)
2025 Mahindra 6075...
