Black sludge in exhaust
/ Black sludge in exhaust #1
bus40
pennsylvania
kioti lb 2204
I have a 1988 kioti lb2204 tractor that has black sludge in exhaust pipe that was dripping out the drain hole in the bottom of the exhaust pipe. I do not run the tractor for extended periods of time could this be a problem that it is not burning out of the pipe or could this be a internal engine problem.
/ Black sludge in exhaust #3
It is likely condensation in the exhaust pipe either moisture in the air condensing or rain that is getting in your exhaust pipe if it is vertical and running down to the bottom. It is mixing with the carbon from the diesel exhaust and forming the sludge. Just run it long enough to burn out the moisture. If the exhaust is vertical, put a rain flap on it will help with the condensation.
It wont hurt anything as long as the drain hole remains open. That is what the drain hole is for.
Thanks for your respose Gary, I keep the Tractor outside all the time but always cover the pipe with a can and tarp the tractor. I took the exhaust pipe off and started the tractor nothing comes out of the manifold that I could see so maybe its just that I dont run the tractor long enough to burn out the carbon.
/ Black sludge in exhaust #6
Water is a main product of combustion. If the engine and exhaust system don't get good and hot almost every time the engine is run, water may remain in the exhaust system and form a sludge with soot..
/ Black sludge in exhaust #7
probably slobber
limited short term runs are PRIME causes for slobber.
take it out and work the bajeebers out of it for 3-4 hours at FULL pto load and rpm. bet it clears right up unless it has been let go so long that you have damage from fuel thinned oil and similar problems..
/ Black sludge in exhaust #8
I agree with sound guy. There are bajeebers stuck in it that you have to work out.
/ Black sludge in exhaust #10
I have the same tractor and just started having the same issues and was wondering how you made out?
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
Wheel Loader Forks (A64126)
Wheel Loader Forks...
2007 CM TRAILER 18' T/A ENCLOSED TRAILER (A65643)
2007 CM TRAILER...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
