Gx345 high idle
/ Gx345 high idle #1
Heinlein0311
Lexington va
John Deere GX 345, John Deere 3320
Just got my gx345 with the 20hp liquid cooled kawi out of the shop. They replaced a lot of parts including the governor. The tractor idles higher than normal no matter where the throttle is at, but once the pto is engaged it's a little better. Is it the governor or the carb that needs to be adjusted? And how do I go about doing it? Also, once I've been using the mower for a while I idle it down for a minute before shutting it off, buy then it gives off a big backfire. Anyone know what causes that?
/ Gx345 high idle #2
How about a list of what things the shop did? Help to know the history that led up to your problem(s).
I didn't quite follow the "tractor idles higher than normal no matter where the throttle is at" statement. Are you saying the throttle has no effect on engine rpm speed? or ??
Does it also backfire if just turning the ignition off without "idle down for a minute before shutting off" ??
/ Gx345 high idle
I bought it from a Deere mechanic. It started smoking like a freight train. So he took it and replaced the crankcase cover, new rings, gaskets, 1 new rod and piston, governor....there may have been more but that's what I remember. It was kind of a weird situation on who should pay for what but we worked it out.
I meant it idles higher than what it should wether the throttle is all the way down or up. There is a difference in rpm when the throttle is moved, although it's the same rpm from the low throttle to half throttle position.
I have not tried just shutting the machine down without idling it down first. I was taught it was bad on the valves and rings and with it having new rings and valves I didn't want to screw it up.
/ Gx345 high idle #4
The governor's job is to maintain a set RPM at full throttle only. It will still have an effect at other throttle settings, but not so much at idle. The idle speed is set with a stop screw on the carburetor. When the throttle lever is set to idle, the governor lever should be forcing the butterfly (On the carb) to the closed position. A screw stops the butterfly valve from closing too far, and causing a stall. This screw sets the idle speed.
The throttle lever on the tractor controls should be able to adjust the engine speed anywhere between idle and the full throttle governor limits. If it does not, it is not set up properly.
/ Gx345 high idle
So by adjusting the idle screw on the carb, it will help the tractor idle better in the idle position but not at full throttle?
/ Gx345 high idle #7
The following from the manual. What are you following for a guide to which screws are available to adjust? A pic of the carb and parts exposed may help give you some thoughts to help you.
NOTE: Carburetor is calibrated by the engine manufacturer and is not adjustable.
If engine is operated at altitudes above 1829 m (6,000 ft), some carburetors may require a special high altitude main jet. See your authorized dealer.
If engine is hard to start or runs rough, check the TROUBLESHOOTING section of this manual.
Possible engine surging will occur at high throttle with transmission in "N" neutral and mower engagement lever disengaged. This is a normal condition due to the emission control system.
After performing the checks in the troubleshooting section and your engine is still not performing correctly, contact your authorized dealer.
/ Gx345 high idle #8
The idle screw setting has nothing to do with full throttle. So I understand your questions better, here is how I view throttle positions:
Idle: The slowest RPM the engine will run. The throttle is all the way down, and the engine is running at a slow speed. Loads of any kind are rarely imposed on the engine while it is idling. Like when you are off the tractor, and do not want to shut it down. Generally, the PTO is off, and the tractor is in park/neutral while idling.
Full Throttle: In most cases this is the working throttle position. The governor keeps the engine speed constant no matter how much load is imposed. Unless the work load excedes the rated horsepower of the engine, the engine should always stay at the RPM set by the governor. Always cut grass at the full throttle position.
Part throttle: Any setting between "Idle" or "Full" The engine runs at a slower speed than full, but produces enough power for slow driving, or maybe pulling a tow behind attachment. Part throttle is also good for faster warmup on the water cooled engines.
A sure sign of a properly tuned engine is when it runs smooth at any throttle position, maintains a constant RPM, And has a nice smooth idle! When carburetor issues are present, (Such as plugged idle jets.) the engine will surge up and down constantly. It may surge less under load because of the governor opening the carburetor throttle to compensate.
An engine that is idling too fast is an indication that if it were set to idle nice and slow, it would stall or surge badly. Or the throttle control is not properly set up.
/ Gx345 high idle
Your last paragraph is what has been my concern. You would think any good mechanic would realize that it was idling higher than normal. Im thinking the same as you and that if it was tuned down a little it would stall....
Now I'll try to put my symptoms into how you worded it: First, the engine does not surge at any throttle setting. Constant rpm is maintained. It's that the rpm is higher than what it use to be.....there is not much rpm difference between idle and half throttle, after that it's a noticeable increase
/ Gx345 high idle #10
Sounds like the governor setting has been changed to a higher RPM.
That certainly could effect all throttle settings. (including idle speed) If it has been set to a higher speed, that will have a negative effect on engine life and fuel consumption. Restoring the proper setting should be a high priority.
Hopefully, the tech did not raise the RPM's to cover another problem. You will need a tech manual for the proper governor setup. Since there is no surging, adjusting the governor should be all it needs.
/ Gx345 high idle #11
I have a 345 that has the opposite problem. Just last week for some unknown reason, the engine is running too fast. My wife was mowing and said the tractor would act like it wanted to die, so she would throttle it back, the engine would pick back up, and she would continue mowing, then after a while would die. It would start fine. I changed the fuel filter, started the tractor, and noticed that on full speed, or even at idle it was running way too fast. My neighbor has a JD and hers did it a couple years ago. What happens is that it runs so fast that it is using fuel faster than it can go into the filter bowl. I adjusted her carburetor and all has been fine, but on my 345, I don' see where to adjust anything. Any clues?
/ Gx345 high idle #12
Kevin
The carb should be pretty conventional with the adjustment screws and all. How close have you looked?
Problem sounds like possible fuel venting not working, or dirt. But that is just a guess. I'd look at fuel supply to the carb (filter, blockage, fuel pump, etc.) before just playing with carb adjustments first. Just my thought....
/ Gx345 high idle #13
Your 345 will have a "throttle plate" down next to the carb --- sounds like you need to adjust fast idle by using that plate. I may not have this all just exactly correct but basically you move the throttle to the fast position and then loosen the plates mounting screws and move that whole plate just a bit to the right I believe to get fast idle set at 3400 rpm. If you need it, I may be able to find the tech manual instruction to accomplish this. Send me a PM with your E-Mail.
/ Gx345 high idle #14
Bruce
Why not post it here for all TBN'rs to see in the future? Sounds like great info to have.
/ Gx345 high idle #15
I found the Tech Manual procedure to adjust fast idle on the 345. I hope it's attached ---- we'll see.
Looks like it'll work. Needless to say you'll need a tach of some kind (I use a "Tiny Tach"). You'll need to remove the hood and the shield between the muffler and the carb/fuel pump. May need to remove the front bumper if you have the three piece plastic one.
  • JD 345 Fast Idle Adjustment.pdf
2012 WESTERN STAR  4900 SB (A63569)
2012 WESTERN STAR...
2022 Kuhn FC4461 TCD MoCo (A63116)
2022 Kuhn FC4461...
2007 Volvo VNL Truck Tractor (A63118)
2007 Volvo VNL...
2023 Kubota KX057-5 Compact Excavator (A63118)
2023 Kubota...
2011 FORD F-150 (A63569)
2011 FORD F-150...
2015 TEXAS PRIDE GOOSENECK (A63569)
2015 TEXAS PRIDE...
