Mobilfluid 424 cross reference question
/ Mobilfluid 424 cross reference question #1
MinnesotaEric
Super Member
Nevis, MN
Kioti NX6010
My NX6010 among some other brands, takes Mobilfluid 424 which is Exxon Hydraulic 560, Shell's DONAX-TD, BP's Tractran UTH, and ChevronTexico's TEXTRAN TDH. I tripped over an SEA rating of Mobilfluid 424 saying that it is 30W.
I'm wondering what the equivalent to these name-brand hydraulic oils is on the really inexpensive side is, specifically like Fleet-Farm's "Farm-Rated" brand of universal trans-hydro fluid?
Also, can I simply dump in Rotella 10w30 motor oil instead, that too would be less money?
What is everybody's experience?
Should I fork out $750 and get a barrel of MobilFuid 424 and shepherd it around the garage because I don't have local source for name-brand hydro oil, or should I look to the less expensive options at my local Fleet stores?
Mystery oil.​
/ Mobilfluid 424 cross reference question #2
Well what ever you decide to do ( I used the Mobilfluid 424), DO not use motor oil. Tractor fluid is rated to be used with wet brakes, and you have wet brakes. I also believe it has anti foaming additives and other good things designed for tractor use.
Oh how the mystery oil calls to me…. :tractor:
Have you found a least expensive source for 424?
/ Mobilfluid 424 cross reference question #4
It is not very cheap, I think I paid $219 for 15 gallons.. But that is from memory
/ Mobilfluid 424 cross reference question #6
I was reading another thread on here talking about the "picky" Kubota UTD oil spec. I also went to the Mobil site and looked up their 424 and saw that it too met the UTD Kubota spec.
I then went to the Tractor Supply site and looked up the Traveller PREMIUM trans/hyd fluid and it's applicability rating. Both Kubota UTD and J20C were on there. That's good enough for me. However the base stocks were said to be in the 15-20 viscosity weight region. Personally, I think straight 30 is a bit much for getting things going on cold days.
So, when I need fluid I go to TSC and get it or to my local auto parts store which carries a regional brand and the JD J20C is what I look for use in my Branson which requires the premium multifunction oil like most currently mfg'd tractors require. In my 1960's vintage Fords I just use regular Ford 134 rated hyd fluid since I have no wet brakes, tight tolerances, hydrostatics and all that new fancy stuff.
HTH,
Mark
Wound up ordering from the theoilhub.com. With a .mil discount and free shipping it was less than $75.00 a pail.
Silly expensive.
/ Mobilfluid 424 cross reference question #8
Silly expensive.
That really is a pretty good price for it. All of the premium fluids are rather pricey.. You should go to your Kubota dealer and ask for 5 gallons of SUDT2!
/ Mobilfluid 424 cross reference question #9
Kioti has it's own label hydro fluid now too. I bought 2, 5 gallon pails and it was around $17/gallon IIRC. About twice what TSC sells their UTF for.
Personally, I wouldn't opt for the cheapest thing when it comes to critical fluids for an expensive new tractor, especially if HST. YMMV.
2007 Kia Amanti (A66408)
2007 Kia Amanti...
2007 VIKING TRIPLE AXLE TRAILER (A65643)
2007 VIKING TRIPLE...
8 Nissan Wheels & Tires (A65579)
8 Nissan Wheels &...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
