suspension seat
/ suspension seat #1
DJH5000
Bethesda, Ohip
kubota 2320
I am looking for a new, good suspension seat for a Kubota B 2320 - 2014 model year.
Thanks much.
/ suspension seat #2
Welcome to TBN from NY.
TSC has suspension seats from $100 and up. I put one on my previous tractor. Just a plain spring suspension w/ armrests. Adjustable spring rate up to 250 lb. It was not the most expensive but much more comfortable than the factory solid mount seat with no suspension. Some modification was required to mount it to the same sliding plate in my tractor. I guess it depends on how much you want to spend whether you get spring and air suspension, cloth, vinyl, or leather covering. I'm sure Kubota has a suspension seat available for a price.
/ suspension seat #5
I have that exact seat that was purchased through Ferris. I saw the same one on a Kubota tractor. That manufacturer works with quite a few OEM's.
It's a really nice seat!
/ suspension seat #6
The Michigan Seat is the same as Sears Seat (no relation to Sears Roebuck, I asked) They make several OEM seats and are a reputable company.
/ suspension seat #8
Take your seat and install an air ride suspension pack under it with on board compressor and be done with it. Seats all bolt up to ISO patterns and so does the air ride pak. Just a matter of getting a hot wire to the compressor. Thats my first mod on any tractor I own that don't have air ride.
/ suspension seat
Thanks, it is a nice seat and sounds like it will fit-one way or another. I'll contact Northern Tool.
DJH
/ suspension seat #10
Sir, could you give us some purchasing info. on the air seat coversion you mentioned? I have an air seat in my Branson and it is fabulous.....air compressor and all is part of the seat support on it.
I have installed a suspension seat on one of my ZTs and to get it where it was a comfortable ride for my 250# it bottomed out of big chug holes and hurt my back. And, being mechanical, it isn't as smooth in operation as my Branson air seat.
So I took it off (put it on another machine) and got a couple of motorcycle air seat chambers (used on cycles in place of a spring under the seat) and installed them with an air tank (reservoir) that I usually have to fill up every few days from shop air. That worked pretty good but floated too much and when I added one, not two, of the original springs back to the seat it really went well.
However I am interested in what you mentioned and surely other seniors with horribly rough terrain would be also.
Thanks,
Mark
2018 Bobcat QA Cold Planer (A64126)
2018 Bobcat QA...
Colombo Twin Master (A64126)
Colombo Twin...
CASE 105C (A62177)
CASE 105C (A62177)
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
Lowe Quick Attach Post Hole Digger (A66285)
Lowe Quick Attach...
(2) Rolling Carts (A64127)
(2) Rolling Carts...
