Kubota B2400 starting problem
   / Kubota B2400 starting problem #1
goulet
Quebec, Canada
Kubota
Hi all.
I have read a lot of discussions about this Kubota probleme where the starter solenoid clicks about 10 times before the tractor finally starts. Il have had this problem for about 3 years, tried everything (and when I say everything, I mean everything, but cant find the solution.
I read in a post here the someone found the solution but I cannot find the original post anymore. I read it's a JD part that has to be installed.
Can anyone lead me to that post where someone found the miracle solution
Thanks
Gilles Goulet
   / Kubota B2400 starting problem #3
Hi all.
Thanks
Gilles Goulet
Here you go:
http://www.tractorbynet.com/forums/...lem-finally-solved.html?highlight=b2400+start
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
