Unknown part on BX-25
/ Unknown part on BX-25 #1
ehumphre
Fort Valley, Ga
Kubota BX-25
Was doing some work in my garden with my BX-25 when I noticed a small metal object laying in the dirt, It is a small metal bracket with a hole on one side and solid on the other. I can't figure out if it is part of the Kubota or from something else. I've looked all over the tractor and can't see where it might fit. I took a quick look through the manual to see if something jumped out - nothing did. Anyone have an idea what it may be or know where on-line I might could look to see what it is to? Hate to drive all the way to a dealer to see if they can tell me.
/ Unknown part on BX-25 #2
I had a similar experience helping a few neighbors last month. Hauling loam from one neighbors house to another. Backing out of one of the driveways, a shiny wingnutted bolt, laying on the ground, caught my eye. At first, I considered it might be from one of his six kids riding toys, scooter, etc. Asked him about it. I stopped, looked all over the tractor and couldn't see anything missing. Put the bolt in my pocket, and finished up the last little bit I was working on for them. Got home and looked over the tractor again. After staring under the hood a few more minutes, I realised the bolt was missing from the air cleaner.
Glad I picked up the bolt.
/ Unknown part on BX-25 #3
Can you snap a photo of it? I can compare it to ours for you
/ Unknown part on BX-25 #4
Check your foldable ROPS. You may be missing the tightening knob also (I am).
Doug in SW IA
/ Unknown part on BX-25 #5
I'm wondering if it may be one of brackets off one of the fuel filters. You have two filters on the BX, check both of them.
/ Unknown part on BX-25 #6
Doug in SW IA
If it looks like this, this gentleman has diagnosed it correctly! I had found this part on the ground myself and folks on here told me what it was!
/ Unknown part on BX-25 #7
That does look like what he is describing!
That reminds me to go check and make sure everything is tight on mine after lunch today....
Wow - what an awesome site and helpful folks...my problem is solved.........the bracket was indeed off the foldable ROPS.
I would have never figured that out on my own as the installed bracket is very had to see. The tightening knob had come off earlier (in another location - was lucky I saw it on the ground) and I'd screwed it back in - never thinking about a bracket being installed.
After these post suggesting it was off the ROPS, I relooked the tractor and low-and-behold there was a bracket on one side but not the other........it's fixed now. Removed the knob, slide the bracket into the ROPS, re-tightened the knobs (will be something I check regularity now) and all is well.
Bothers me these parts keep fall off - hope I keep finding them. Love this tractor - use it a lot so I guess I just need to be a little more careful and recheck parts that vibrate and be sure they are secure. Too that end - anyone else find other parts that have "fallen off" that need to be checked on a regular basis.
/ Unknown part on BX-25 #9
On my older BX, these parts are unnecessary when the ROPS is folded down (the case almost all the time). I leave the knobs and brackets back at the garage for safekeeping.
/ Unknown part on BX-25 #10
I just bought a BX1870 (sadly, with the older 90° ROPS, not the new -1 ROPS that folds all the way down. What purpose do the knobs serve? As best as I can tell, they seem to possible be an anti-rattle measure? The pins hold it solidly in place when up.
/ Unknown part on BX-25 #11
Correct, they prevent rattle when the rops is raised and the knobs are tightened
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
(10) Chairs (A64127)
2026 SDlanch SDLE20 (A64127)
2026 SDlanch...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2011 Utility Trailer 53' Reefer (A64127)
2011 Utility...
