Mendonsy
Sorry I didn't see this thread earlier. I went through the same process last year so maybe I could have save you some time.
It looks like you have done basically the same things that I did so you should be in good shape. Mine is holding up well going into the second year.
There are three additional things that I did to mine which you might want to consider:
1) I added a 20" Durafan shutter fan at the top center of the end wall (QC supply).
2) I added an 8000 BTU Procom propane heater about 3' up on the end wall (Northern Tool).
3) I insulated the whole thing with bubble wrap.
The fan keeps the inside temperature at about 5 degrees above the outside temp in hot weather and direct sunlight (with the doors open). The heater and bubble wrap keeps the inside temperature above freezing down to about 5 degrees F outside.
The attached picture was taken on 5/21.
