1964 MF135 gas, need voltage regulator schematic
/ 1964 MF135 gas, need voltage regulator schematic #1
wadewells
AL.
M F 135
My old 135 had a GM car voltage regulator for years, now that I have the correct regulator I need a schematic diagram to wire it correctly. I think I can do it but would like to see a schematic to verify. I know it's probably in the manual but rather not wait a week for delivery. :)
Thanks!:thumbsup:
/ 1964 MF135 gas, need voltage regulator schematic #2
What engine do you have? BobG in VA
BTW, a U. S. made Echilin regulator was only $10. more than the fitz-all Chinese part.
OK, have a real problem now. Put the new regulator on and it's charging but as soon as I turn the engine off the regulator gets really hot and one set of contacts glow red.
A=Armature
F=Field
Batt=12V (yellow wire)
L=Lights.
There is a braided white wire from the switch that I thought went to the L terminal, maybe not?
/ 1964 MF135 gas, need voltage regulator schematic #6
http://www.tractorshed.com/gallery/uptest/a53575.jpg
Thank you Kenneth S., I had the thing wired wrong. Had the battery and light wire swapped. All works as it should thanks to the diagram.
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
17501-FL (A56857)
17501-FL (A56857)
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
6' Fork Extensions (A60463)
6' Fork Extensions...
