New Home Construction
/ New Home Construction #101
I'm not sure which area you are talking about. Are you talking about where the floor trusses are? If so, they just hadn't gotten to that yet. The put it on the walls of the main level before they stood them up, then came back later and finished the rest.
Looking great!!
Lots of little things going on at once. Cabinets have been finalized and marked, plumbing is being roughed-in, HVAC work, etc. Brick layer is supposed to be here on Monday, so it will really start to take shape on the outside next week. Not a whole lot for pics, but here they are anyway! :)
Geothermal wells going in:
382455-new-home-construction-wp_20140702_004-jpg
Missed pics of the water well being drilled, but the pressure tank and spigot are in:
382456-new-home-construction-wp_20140710_001-jpg
382457-new-home-construction-wp_20140710_005-jpg
The concrete steps for the deck:
382460-new-home-construction-wp_20140708_007-jpg
And most of the ductwork for our 5-zone heating and cooling system:
382458-new-home-construction-wp_20140710_003-jpg
382459-new-home-construction-wp_20140710_004-jpg
WP_20140702_004.jpg WP_20140710_001.jpg WP_20140710_005.jpg WP_20140708_007.jpg WP_20140710_003.jpg WP_20140710_004.jpg
/ New Home Construction #104
Looking good!
/ New Home Construction #105
How many wells did they end up drilling? I thought hard about geothermal when we built a few years ago and am still thinking about it.
We ended up with 5 wells, enough for 6 ton of capacity. We are putting in a 5 ton unit, but added the extra well for added efficiency. We have geothermal in our current house and love it! Our bills went down while keeping the temperature cooler in the summer and warmer in the winter after we added it to our current home.
/ New Home Construction #107
Did you think about open loop geo thermal? When we built last year well driller talked us into it,it uses drinking water well for geo,then dumps into lake. Didn't have the cost to drill extra geo well,plus got 30% tax credit on drinking water well,which we wouldn't have gotten if it was strictly for drinking water,just curious.
I did, but I didn't do a whole lot of research on it. I was thinking the extra cost of electricity to pump that water out then dump it somewhere wouldn't be worth it. We don't currently have a lake, but it would have been a nice way to help fill the lake and keep it full once we do have one! :) Our utility around here prefers the closed loop as well, and I'm getting a decent rebate from them. I didn't think about the 30% tax credit on the water well though. I probably should have researched a bit more.
EDIT: I just remembered a big reason we went closed loop. Our water around here is pretty hard, and they don't recommend that on the WaterFurnace unit we used. You have to descale and de-lime your unit regularly and I want to avoid that.
/ New Home Construction #109
Normally it's 1 ton per well, or 1 1/2 tons per well. with 5 wells and 5 tons, you probably don't have extra capacity. What size are the loop pipes in the wells and lengths, that is usually a good indication. I have designed and installed geo systems.
The house looks great. I was unfamiliar with zip panels, I have seen them used here but didn't know what it was.
Yeah, it's normally 1 ton per well. I think they just went a bit deeper in each well instead of drilling an extra well. I'm not sure of the size and lengths of the pipes.
I double-checked with the drillers today and they did just go deeper on each well. He said they needed 900' total for 6 ton and just did it in 5 holes. That would make it 180' / well.
Bricking began yesterday. It's amazing what a difference a little brick makes!
attachment.php
attachment.php
/ New Home Construction #113
Moving right along! I bet y'all are getting excited!
Brett
/ New Home Construction #115
Nice of them to lay plastic down. I've seen it where they just destroy everything around the house by the time it's done and you have to spend a week just cleaning up their mess. Looks like you got a good crew!!!
Eddie
/ New Home Construction #116
Eddie
Yes, I was very appreciative of that! I've been impressed with the crew so far. Our contractor (who is VERY particular) was even impressed. His normal brick layer was backed up and couldn't get to it, so we chose this crew. They seem to pay great attention to detail.
fordmantpw,
Looking good.
Did you post any plans? I am curious about the support wall under the deck (on the left of the picture). It looks architecturally interesting. Not the standard look.
I don't think I have posted any plans, so I will add them here. That support wall you are seeing there is just the steps (which are in a different place than what the plan shows). I didn't fit the whole set of stairs in the pic, so it does look rather goofy. :)
Main floor: main floor9.jpg
Basement: Basement Floor 9.jpg
Looks awesome! I've been dealing with siding issues the last few weeks. My next house will be ALL brick...or at least mostly.
Thanks! We went all brick for zero maintenance. Just don't want to deal with siding issues, hail, rocks thrown from the mower, etc.
/ New Home Construction #120
Looks good, I really like the brick color. We had pretty much all of our house bricked for the same reasons and haven't regretted it at all.
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2015 John Deere 319E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2011 CARGO CRAFT PUMP CONTROL TRAILER (A67714)
2011 CARGO CRAFT...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A64279)
2026 DEVELON...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
