Mowing a silly question
/ a silly question #1
heescloud
blue springs
l100
I acquired a L100 lawn tractor. It hadn't run in years. I finally got her running and feel I at least should replace the belts. However the belt that runs from the transmission to under the motor seems strong enough to at least pull it from my shop but she doesn't budge. I've never owned a Deere much less this model and am not certain the operating protocols one bit. Might I ask you kind folks to tell me the steps to engage the drive belt and such. Thank you, Mike
/ a silly question #2
look in the back end of the Machine and see a rod coming out the back end,below back of seat.pull rod out it disengages the transmission,push it in and engages transmission.this is the way my l130 is.
/ a silly question
No Sir my model does not have that! If someone could tell me how to tighten the drive belt to the transmission, that's all I would need. Mines L 100.....
/ a silly question #4
Does it roll when you push it,could it be that parking break engaged.
/ a silly question
Again,,,,,,, the machine rolls, the parking brake is not set, I only need to know how to tighten the tension on the transmission drive belt!!! Thanks, Mike
/ a silly question #8
....I don't see were that shows how to tighten tensioner.
Only guessing , but is there an tensioner pulley, that requires a spring?
http://outdoorpowerinfo.com/repairs/deere_110a_yellow_drive_belt.asp
This seems to infer that setting the parking brake takes tension of the idler/tensioner pulleys, releasing the parking brake then lets the spring tension the pulleys onto the drive belt.
/ a silly question #9
I have a JD G100. Check the tensioner pulley system. Many times after the mower sits for extended periods the springs and slides on this pulley sort of "lock up" and will not provide the needed tension. The tension for the main drive belt is thru this tensioner pulley - this entire tensioning system must move freely for the springs to provide adequate tension to the pulley and so the pulley will pull on the drive belt. Without this the belt slips on the drive pulley and also slips on the system driving the blades.
Cleaning any build-up of "gunk" and some spray lube could have it running again.
Another point - I've had the drive belt "jump off" the main drive pulley - check that the drive belt follows the correct path around and thru all the pulleys.
/ a silly question #10
I have never seen any HST transmission that doesn't have that neutral lock out for the rear end. Either your tractor is a gear drive or you are overlooking the transmission unlock mechanism. Look closer for one, it could just be a spring type that your raise and lock into a notch. Unless you have a clutch on it, you WILL have this neutral lock out, they are on every HST lawn tractor.
/ a silly question #11
First, you need to know the components in the drive system (belts, pulleys, springs, etc.). Make sure all parts are there and working freely.
My guess would be that the spring is broken/missing or the plate the spring is attached to is frozen. When the brake is released the spring should allow the belt to tighten. There is no adjustment.
(Note: There are two pulley positions on the engine shaft pulley. The smaller diameter drives the transmission, the larger drives the mower deck. Both are often referred to as "drive" so there may be some confusion as to which system you are referring to.)
Here is a photo:
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
TEST YOUR BID BUTTON! (A64281)
TEST YOUR BID...
LS MT225E (A64126)
LS MT225E (A64126)
2025 48in. Farm Jack (A61572)
2025 48in. Farm...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
