deere 345 throttle
/ deere 345 throttle #1
mikehaugen
Elite Member
Lee, IL
John Deere 1070
My mom has a 345 with 20hp kawasaki. The throttle constantly creeps down while mowing. I have mowed her lawn a few times with it and realized how annoying it is. Every minute or 2 you have to bump it up. Can't easily see the bottom of it because it is built into the dash. Before I tear into it, is it worth it? Is there even anything at the base to adjust, like friction discs or something? Is this a common issue? I'll probably talk to the deere dealer one of these days to see if there is a fix for it, but in the meantime I thought you folks may have ideas.
/ deere 345 throttle #2
Looking at the throttle mechanism under the "dash" there doesn't appear to be a friction adjustment. But may be worth a look at both ends of the throttle cable to see if something is loose or missing (i.e. broken part).
You can see the breakdown of the parts on jdparts.com if you want (free registration).
/ deere 345 throttle #3
There's a throttle plate down next to the carb. I don't recall any adjustment there, but that plate is the source of the friction to hold the throttle in position.
/ deere 345 throttle #4
Looking at the throttle mechanism under the "dash" there doesn't appear to be a friction adjustment. But may be worth a look at both ends of the throttle cable to see if something is loose or missing.
Some mowers have a spring associated with the governor linkage. Is it possible someone installed the wrong spring?
Or is it possible you have it adjusted to run the engine too fast?
Thanks for the replies guys. I will check these things out further next time I'm there.
2008 TRITON TRAILER WACKER MGT2S GENERATOR (A65643)
2008 TRITON...
INGERSOLL RAND 80 GALLON COMPRESSOR (A65643)
INGERSOLL RAND 80...
2013 WYLIE WATER TRAILER (A65643)
2013 WYLIE WATER...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
