Wood splitter motor
/ Wood splitter motor #1
escavader
western maine
bx-23 ,
Anyone ever use a vertical shaft lawn tractor motor on a woodsplitter? I just pcked up a parts machine and it runs like a top (thedeck was bad)it had a nice little14 hp kohler on it purrs like a kitten it even has new battery
Thinking of upgrading my little 5 hp briggs
I can fabricate a mount etc get the correct pump adapter what do you all think will it work ?
/ Wood splitter motor #2
Seen a pile of them in that configuration at the big box stores. They tend to be cheaper units with a push mower sized motor.
No reason it would be an issue if your pump fits & doesn't mind the vertical mount.
/ Wood splitter motor #3
I have a Huskee 35 ton with an 11.5hp Briggs that is a vertical shaft and I haven't found any thing that it won't split! 14hp should be plenty if you have the right pump. One of the hydro experts should chime in soon and let you know!
/ Wood splitter motor #4
Used an electric start 16 HP on the splitter I built a few months ago. No issues at all, but I think there are some pumps not reccomended for vertical.
May have to fab a pump Mount. And get the right sized Lovejoy's.
But I will say this, going with a bigger motor won't gain you anything at all. Speed and power is determined by the pump, and then a motor sized accordingly. So without getting a bigger pump to go with the bigger motor, you won't see any change in performance at all.
/ Wood splitter motor #5
I could be wrong, but i don't see why the pump couldn't be mounted vertical.:confused:
I have the two stage barns on my 5 hp briggs im really not looking for more power orto split faster its just the briggs is old i think it could even have points
I just thought the 14 was quieter it is more horse power (like i said doesnt really need to be faster)
It has an oil filter on the kohler and all it will do is sit and idle the pump does it all
I cant see an issue with pump verticAl i might have to make a plate to bolt it up no biggy
If its electric it would be easier for wife to start she likes to split wood
Im gonna use it this summer with the briggs and save this project for winter when snows deep keep your ideas coming thanks
/ Wood splitter motor #7
Well, if the goal is electric start, and quieter then I dont see any issues.
Just wanting to make sure you didnt have the mis-conception that you would be getting more splitting power or speed.
/ Wood splitter motor #8
Typically gear pumps do not have limitations on how they are mounted. Axial piston pumps on the other hand typically require special modifications or considerations for vertical shaft up mounting to insure that the input bearing gets lubrication.
Your vertical shaft engine might have a mounting pattern for which you can purchase a pump / motor adapter similar to a C-Face design on electric motors.
/ Wood splitter motor #9
I would definitely find out somehow from the manufacturer anout approved pump configuration. Many pumps only have radial bearings/bushings and cannot take any kind of side loading or "thrust" force. Even the weight of the pump rotor will put thrust loading on the pump and it's life will be severely shortened by running it sideways.
/ Wood splitter motor #10
You should build a riding welder. I've seen guys take a good mower with a bad deck and install a welder/generator head so the belts that ran the deck run the generator/welder head. Throw some leads on it and it's pretty darn useful machine.
/ Wood splitter motor #11
my homemade splitter currently has a 12hp b&s vert shaft engine, and i will be soon replacing it with a 13hp kohler command vert shaft. its a good way to reuse vert shaft engines, b/c they arent good for much else.
/ Wood splitter motor #14
I'm sure you know even though the engine is a lot bigger it will still have to turn the same rpm as the 5 hp engine. Maybe you can belt drive the pump and run the engine slower. Maybe that's what you meant anyway.
/ Wood splitter motor #15
At the very least he could adjust the pump so it stays in high flow until a higher psi to take advantage of the extra HP. Most 2 stage pumps have an adjustment range of ~400-900 psi (before it goes into low flow/high pressure)
Assuming he has an 11gpm 2 stage pump 14 hp could easily move 11gpm at 900 psi. It most likely is set close to 400psi with a 5 hp engine.
900 psi is probably enough to split most pieces without going into low flow (assuming he doesn't use a 4 way)
I've been thinking about how to modify the adjustment range on a 2 stage pump so I could pair it with a 13hp Chonda. My goal would be 11gpm at 1750 psi so that even with a 4 way it usually won't go to low flow...
/ Wood splitter motor #16
I went to Northern Tool for the 16 gpm pump, adapter bracket to a V belt pulley, and the Lovejoy connectors. I had a 15 hp lawnmower with a shot deck and since my Fords were low on gpm and slow, I decided to build my own; besides it gave me something to do. The pump requires 8 hp to run the 16 gpm at 2000+ psi. The engine just loafs.
There are pictures of it on here in the archives. Built it sometime last fall. Since the pump was driven off the sheave mounted to the engine shaft via a rigid mounted sheave as the power receiver with V belt drive, I had to mount the pump with the shaft up (to get the pump to rotate in the required direction) which forced it to mount below the frame rather than on top. Made for some ground clearance complications I had to overcome. Vertical mounting was no problem with respect to pumping ability.
In terms of performance it is 6 seconds out and 7 back on a 4" x 24 stroke cylinder. Things have to be considered like return hose size and overall hose length to get that kind of cycle time. WWW is full of info on answering questions you will have. You need a controller (OC bidirectional valve) obviously and a reservoir with an inlet filter to it preferred. I put QDs on my controller so that I could disconnect the cylinder which assisted in the ease with which the rig moved.
Mine rolls around easily even though I had to abandon the idea of making it self propelled. I did put 2" x 22 I think, solid tires on it for ground clearance but that made it really easy to push around and since they were much thinner I could get much closer to the mower for things like pushing it. The pump hookup got in the way of where the propelling v belt would run. I learned that these little pumps can't tolerate any lateral pressure so you have to essentially contain everything and all the pump sees is radial pressure via the Lovejoy couplings required to disconnect the pump from mounting stresses associated with supplying drive power. NT had all that including the valve (special log splitter application) and very reasonable considering.
On comparing to store bought, comparing functional apples to apples (gpm, speed, pressure) I'm pretty close in expense to the low end splitters but I can outperform them hands down and I like my setup better. Additionally, I did it, it gave me something to do, it gave my retired mind a workout which it needed, and the old mower was just sitting around collecting dust and on and on. I certainly would do it again.
HTH,
Mark
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
New Holland BR7090 Round Baler  5x6 Bales (A63688)
New Holland BR7090...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
