STORING ATTACHMENTS
   / STORING ATTACHMENTS #31
Just an update: Picked up a set of 1500 lb vehicle wheel dollies from HFT. They work great, the box blade rolls with very little effort, not bad for 1260 lb box blade. ($49.95 with coupon for a set of 2) Just remember the 67338 have steel wheels and the 60343 have plastic wheels. (I have the steel wheels)
Vehicle Dollies 006.JPG Vehicle Dollies 007.JPG Vehicle Dollies 008.JPG Vehicle Dollies 005.JPG Vehicle Dollies 012.JPG
   / STORING ATTACHMENTS #32
issue 1 for me, keeping the stuff out of the weeds.
issue 2 for me, keeping the stuff out of the mud.
issue 3 for me, i will most likely use multi 3pt hitch stuff in one go, say bottom plow, disc, drag harrow, rear blade, all in one day. and not have a chance to go at project for another few days because of rain.
issue 4 for me, trying to turn tractor just right inside of a shed to drop off / pickup another attachment, "dirty attachment from just using it"
issue 5 not enough time before next rain comes along to clean between using different implements so they may stay dirty for some time.
issue 6 i hate tarps, a good wind, and a tarp will get destroyed quickly. from a sharp corner on the implement/attachement, to just trying to strap a tarp down to keep it from blowing off. not to mention mice and other critters wanting to build nests, if you tarp it up to good.
most 3pt hitch implements are built heavy duty enough to last years setting outside. the bigger issues setting outside, are the sun rays, on rubber (from tires, to hyd hoses, belts), and then rain/snow/ice, and the rust that comes along with everything.
personally prefer a "lean to" shed, or extension to side of the shed, were roof just extends out say 6 to 10 feet from the side of the shed. just enough to cover stuff below, and keep majority if not all of all sunlight and rain/snow/ice off the stuff. i say majorty due to high winds coming around and wiping some rain/snow/ice up on to some stuff.
easily backup to each implement without extra stuff in the way, and i can turn garden hose on/ pressure sprayer on, without fear of getting everything else inside a shed for example dirty/wet.
not really loosing valuable floor space inside the shed itself. or wall space.
the bigger issue with this is, you need more driveway, to get around to side of shed, or you will be dealing with a rutted muddy mess if driving over lawn to get to the area.
   / STORING ATTACHMENTS #33
View attachment 382536 View attachment 382537 View attachment 382538 View attachment 382535 View attachment 382539
I use the same dollies on some of my heavier equipment.IMHO they work great on cement floors.
   / STORING ATTACHMENTS #34
Just an update: Picked up a set of 1500 lb vehicle wheel dollies from HFT. They work great, the box blade rolls with very little effort, not bad for 1260 lb box blade. ($49.95 with coupon for a set of 2) Just remember the 67338 have steel wheels and the 60343 have plastic wheels. (I have the steel wheels) 60343 have plastic wheels <img src="http://www.tractorbynet.com/forums/files/attachments/382533-storing-attachments-vehicle-dollies-002-jpg"/> 67338 have steel wheels <img src="http://www.tractorbynet.com/forums/files/attachments/382534-storing-attachments-vehicle-dollies-003-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/382536-storing-attachments-vehicle-dollies-006-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/382537-storing-attachments-vehicle-dollies-007-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/382538-storing-attachments-vehicle-dollies-008-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/382535-storing-attachments-vehicle-dollies-005-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/382539-storing-attachments-vehicle-dollies-012-jpg"/>
Looks great.
I used the wooden dollies from HF to make mine. Think that is posted somewhere on TBN.
I still need dolly for my backhoe, will have to look at these.
David Sent from my iPad Air using TractorByNet
   / STORING ATTACHMENTS #37
I am also looking forward to your build. This is a project that is on my list.
   / STORING ATTACHMENTS #38
Are you using the 67338 with steel wheels or the 60343 with plastic wheels.
   / STORING ATTACHMENTS #39
I have one pair with plastic wheels and two pair with steel wheels.Both have held up well.
   / STORING ATTACHMENTS #40
That's my next project, backhoe attachment dolly
That's my current (but not yet started) project. Keep us updated! (please) :cool:
Anybody have opinions on whether the wooden or automotive (shown) dollies are superior? I am using the wooden ones for my land plane and am wondering whether the ones shown above are superior. Does more expensive = better? :laughing:
2011 John Deere 120D (A47477)
2011 John Deere...
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
2016 Ford Fusion SE AWD Sedan (A55758)
2016 Ford Fusion...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2011 Nissan Rogue SUV (A55758)
2011 Nissan Rogue...
