George2615
Super Member
Well, new to me.
Found a good deal on CL for a PHD. Went to look at it. Gearbox felt nice and tight, no slop. But frame has seen some abuse. Auger is the heavy duty 9" double flight but shear bolts are wrong size and bent. Boom adjust holes are all oblong. Lift pins are loose. PTO shaft yokes are good but U-joints are bad. Generally sound just some U Joints, new pins, make a new boom adjust out of C channel. Unit weighs 198#. I found the center of gravity and will weld on a lift hook.
