Mini Hydraulics?
/ Mini Hydraulics? #1
chopped
New England yankeee
Might sound odd but I was wondering if maybe there is such a thing. Im thinking it would be a device to reduce the pressures of the pump and then be able to use smaller hoses etc. and lower pressure ratings. Coupled with some smaller things like rotor motors and actuators etc. So many different possiblilites spin the chute on snow blower, move the levers on the quick attachs etc. Id think the costs would be much less
/ Mini Hydraulics? #2
Smaller hoses does not limit the pressure.
As a matter of fact, smaller hose can handle more pressure that large hose.
The design of the pump dictates the pressure potential.
/ Mini Hydraulics? #3
what you are referring to is called a Pressure Reducing Valve. Very common in construction equipment with "pilot operated" controls. It uses supply oil from a gear or piston pump and limits the flow and pressure of oil to lower volume/pressure. The unused oil from the pump is either dumped to tank or in most cases directed to other functions. It can be setup to work with Open Center valve systems but more easily done with Closed Center Valves and Supply on Demand Piston Pumps.
/ Mini Hydraulics?
I guess I was more in the thinking process of why they dont have a smaller ""branch'' off of hyd. that could do all the ''lazy'' chores that are helpful . My prime example is snow blower.Look at the size of the turn motors and the size of the hoses ,connectors etc. Now imagine a small reducing valve to lower the pressure and then in turn can handle smaller motors and hoses to spin the chute. Surly if i can spin mine with a windshield wiper motor then it does take that much ,The same would go for the up and down of the chute. Also the levers on the quick attaches. on a loader could be done cheaper, less bulky .
I assume that if I think cost, then its not going to be as cheap a replacem,ent as a linear actuator and a 12 volt solidoid.
/ Mini Hydraulics? #5
Using the snow blower as example; if the pressure was reduced it means the maximum torque to the motor and work force of the cylinder would be reduced which may cause them to stall easy. So reducing pressure might require an even larger motor or cylinder. Reducing the flow without reducing max. available pressure would allow for easier, more precise, movement without sacrificing work force. A simple orifice in the line will give this same result.
/ Mini Hydraulics? #6
chopped,
This pump is a 5 lb pump, about 3.82" x 2.8" x 3.66"
It only pumps about 1.04 GPM, but at 3000 psi continually, and 4000 psi intermittently.
Speed of a hyd motor or actuator is determined by GPM. Larger pumps provide more GPM.
Pressure potential is built into the pump and motor, but the pressure is developed in the hyd components based on load.
Pressure = Force
My hyd pump is driven by the fan belt of the engine.
I have a similar pump on my Power-Trac for the loader, and it does everything I want.
0.067 CU IN MTE D201-5486 HYD PUMP
The hyd power-pac's on boats to lift and lower the motor are very small and include the reservoir, and run on 12v.
I have one and use it on a land plane to raise and lower the wheels.
They pump about .25 GPM
You can get small, but you have to look for it, and it will probably cost more.
/ Mini Hydraulics? #7
windshield motor can turn the chute... so why do you want a hyd unit? vs a 12v electrical actuator or motor to do this or that?
i would think there would be a lot of extra cost, from quick connect couplers, to valves themselves, vs a 12v dip switch, a trailer plug end, and some wire, and either electrical motor or electrical actuator.
/ Mini Hydraulics?
This is sort of my point. I see so many set ups with rather large hoses and valves and motors.
/ Mini Hydraulics? #9
Why not just put a couple of reducers prior to a pair of QDs and run smaller lines for your smaller motors/cylinders?
I'm running 2 pair of 1/4" and 1 pair of 3/8" QDs on my tractor. The 3/8" runs the backhoe, and one of the 1/4" runs my hyd thumb on the BH. I use both pair of the 1/4" for the chute rotation and deflection on the snow blower.
/ Mini Hydraulics?
good point. I have one run of 1/4 in the area. What I was imagining was some sort of branch off system that would use very low pressure lines and valves and motors and actuators etc. thus reducing the bulky and also the cost should be less.
Much like power steering pumps and hoses..
in a house we dont run number 1 wire when simple 14 is workable. etc.
/ Mini Hydraulics? #11
...in a house we dont run number 1 wire when simple 14 is workable. etc.
Sure but you still push 120v thru the strand regardless of guage.
Is a power steering setup really that much lower pressure than a hyd system? Any of the ones I've worked with seem very similar in design
/ Mini Hydraulics? #12
frankly i am still on side of why you even want smaller pressures / smaller GPM of hyd fluid vs just going with electrical. and at moment it is coming down to over all expense, and needing a spreadsheet basically for a price comparison. and then some con's/pro's. of the smaller hyd package vs electrical setup.
i have also been trying to think, what is out there, that uses multiple hyd cylinders and/or hyd motors, or like....
with electrical actuator for example, it would be easy to install or adjust sensors for fully extending/contracting the unit. so you are not destroying something. and then ya get into a whole mess of crud, over complicating things i would imagine with extra sensors and stops and like....for similuar setup, you would need to run both hyd lines and electrical wire to given spot... so you have them sensors...
well i guess i can take that back.... pressure relief valves, and making sure linkages, would allow fully extension and contraction of a hyd cylinder. but for a hyd motor vs electrical motor.... and say chute on a snow blower, and not wanting to turn the chut complete 360 degrees... i suppose you would quickly notice when ya turned the chute to the point it is blowing all the snow directly into the radiator and more so directly into your face LOL. but... hopefully idea gets across. (ughs been there done that on the old walk behind push snow blower)
hhmmsss i would imagine you would find a good amount of lower pressure and lower GPM items for robotic assembly lines and various manufacturing plants possibly.
LEGOS! pneumatics yAA!!!
i guess what max pressure do you want to work with, would be a starting point.... and then go from there for GPMs for a pump, and dealing hyd cylinders and hyd motors.
perhaps going with generic "air tools and equipment" of max 200 PSI. or 150 PSI you would be getting away from the more expensive and complex hose connectors that require more specialized and expensive tools when dealing with 1000PSI, to 1500PSI, 2000PSI, 2500PSI, 3000PSI, and on upwards higher PSI that you might find on current tractors and there hyd max pressures.
i doubt you would want to use air due to it compresses, but MAX PSI of 150 PSI, and using hyd fluid, you would more likely be able to use off the shelf fittings from any hardware store "within reason" of course.
perhaps a 12V on demand sprayer pump that can be used with a hand wand. some of those units can get up there in max PSI. and just going with a hyd fluid vs water and chemicals...
i wonder if you could find the lower PSI hyd cylinders and hyd motors. perhaps on some of the online stores that gear towards more for those "robotic wars" or what ever it is called on tv.
if ya keep the PSI down, abilty to use regular water valves, for drinking water and like could be had and used... though for life of me can't think of any multi function valves that deal with lower PSI...
i guess i am changing my tune from against. to with your thinking.
/ Mini Hydraulics? #13
I would think running an automotive power steering pump for your micro circuit hydraulics would be a very practical way to do what you are describing. Maybe off an engine V-belt sheave. Find a steering rack and you've got an almost made-to-order chute rotator. I was thinking of doing something similar to offset my rear blade before I installed remotes.
/ Mini Hydraulics? #14
You just need a flow divider valve. Very commonly used to run power steering from a big hyd circuit. If you want to limit the pressure just put a pressure relief valve in the low flow circuit. Flow divider valves are available with either fixed or adjustable flow on the controlled port. The remaining flow is used for the original higher flow circuit.
/ Mini Hydraulics? #16
chopped,
Pressure = Force
YEs. They have small 12v pumps with reservoirs that adjust the drive up and down and for other things like trim tabs. The trim tabs pumps are easy to use and you could even put a nice control switch on your dash, some even have level indicators built in.
2016 Ford F-550 Mason Dump Truck (A64556)
2016 Ford F-550...
121A (A63745)
121A (A63745)
2008 CATERPILLAR 420E IT BACKHOE (A65053)
2008 CATERPILLAR...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
UNUSED PARBREAK GCC56 2 PRONG BALE SPEAR (A65055)
UNUSED PARBREAK...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
