What am I missing about removing Draft Link (3720 Cab)
   / What am I missing about removing Draft Link (3720 Cab)
Thanks, didn't know that. Advice on a jack good enough to take hitting the pin from the side?
   / What am I missing about removing Draft Link (3720 Cab) #12
The R-4 loaded should just stand on its own, at least mine do. Has not been a problem to handle them alone.
Long time no see, glad to see you are back.
   / What am I missing about removing Draft Link (3720 Cab) #13
I guess another option would be to visit the local auto parts store and rent a ball joint press. From the looks of it, the press should fit around the frame, but I'd measure before you bring it home just to be on the safe side.
   / What am I missing about removing Draft Link (3720 Cab) #14
You need to rotate the pin (flat part on inside that bolt went through is attached) about 90 degrees back then it slides out to the inside. I have to take mine off on 3520 to put backhoe on. Never had a problem; slides pretty easy. If it is not rotated it will not move.
   / What am I missing about removing Draft Link (3720 Cab) #15
Not sure if this is the case on the cab model, but on the open station the flat part doesn't have to rotate at all for the pin to come out.
Matt
   / What am I missing about removing Draft Link (3720 Cab) #16
I agree with yooper68, that if the keeper bolt is out (and you said it is), then rotating that pin by a flat bar or large screw driver is the best way to get it broken loose.
Hitting with a maul or putting pressure from a bottle jack may just break a casting. THAT be expensive...
Interesting that that pin LVU15084 lists for around $25, except Sears has it listed at $94. Same part no.
   / What am I missing about removing Draft Link (3720 Cab) #17
Just looked at mine again. Looks like it doesn't need to rotate but I always do. Can't remember why. There is a slight groove across pto housing cover that it slides in.
F3506 , Thanks appreciate the suggestion. I'll measure and try.
Thanks Matt.
beenthere, are you saying to pry the flange that holds the keeper by prying in down, leveraging against the 3PT casing?
1999 CHEVROLET C7500 UTILITY TRUCK (A59575)
1999 CHEVROLET...
2003 Big Tex 10PI...
2001 Freightliner FL80 Bucket Truck, VIN # 1FVDBXAK01HG77631 (A57453)
2001 Freightliner...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56860)
2025 MS380R Mini...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
