Loader tractor problem
/ tractor problem #1
onagon
iroquois falls on
john deere 6430
hi
I own a 6430 john deere tractor and loved it. I had no serious problems with it till this week when I traveling down a concession road and I hit a bump in the road
and my bucket fell off. The tractor ran over the bucket and then caught fire, in no time a all the tractor was gone. The Bucket is spring loaded and it was secure I always double check. I don`t know how that bucket fell off. I`d like to know if any one else had a similar problem with there john deere loaders.
/ tractor problem #2
Had a neighbor burn his up last year....don't know how it started.
/ tractor problem #3
What model loader? If the 640, JD has HD latches that are pinned, not spring retained. Maybe I should switch? Whole Goods Number is BW15242
/ tractor problem
my loader was a 563 spring action, my tractor only had 500 hrs on it.
/ tractor problem #5
Did the bucket falling off start the fire, or was that 2 separate incidents?:shocked: Must have been a pretty rough ride in any case.
/ tractor problem #6
Does your loader have the 500 series carrier? Has two lynch pins to retain the bucket. Or the global carrier with a horizontal bar to retain the loader?
/ tractor problem #7
hi
H,mm any pics?
/ tractor problem
the bucket falling off started the fire. We don't know why that would make it catch fire, but it did.
/ tractor problem #9
/ tractor problem #10
If you ran it over it could have ruptured a oil/hydraulic line that sprayed on a hot surface, thus starting the fire.
(9) SEMI-TANKER TRAILER PARTS (A64280)
(9) SEMI-TANKER...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
