I'm sorry this is taking so long to resolve, so I appreciate you all sticking with me on this til I can get it resolved. I only get to work on mechanics on weekends or a day off. So, the thermostat (160) has been installed now. I can see water flow inside the top of the radiator (with the cap left off). It appears to (as I stand facing the front of the tractor) to be flowing from my left (where the top hose enters radiator) diagonally to the right. Is that the correct flow pattern? The water pump is not leaking. The temp guage was replaced by the PO, and is only 10 months old. I did a little discing this morning, and I was optimistic. Temps looked good. Then I went to try to finish my mowing job in a thickly grown up old field which includes saplings here and there. I am using a JD 509 five foot bushog. After awhile the temp guage reached the red zone and I cut it off. Here we go again. I think I said before the PO said he had the radiator cleaned and flushed, and the manilla tag was still hanging on it from the rad shop until just last week, so I assumed that is OK. As far as the fins maybe being clogged, the fan has an intact shroud, and definitely sucks air thru it, be it leaf particles, or a dangling rag, so I can see it is passing air thru. I see no oil in the water, nor water in the oil. I hope I have addressed all the previous response questions and suggestions.
Is it possible a JD 509 is too big for this tractor? Just asking out of desperation. :confused2:
