the old 1950ish allis chalmers CA, tractor after about 4 hours maybe 6 hours pending on temp outside, non stop mowing, "high throttle / RPMs non stop with a good load on the tractor", it gets to the point it will want to over heat. and its time to stop and let it cool down for a hour or more.
generally flush radiator yearly. and each time, i get some "rust" pieces coming out of it. i generally toss in some sort of anti rust / corrosion additive to the 50/50 mix i put into the system.
1 flushing system for me.... undo drain plug at edge of radiator, and drain to bucket with a hose.
2 get the garden hose out and place it into the radiator top. and just let it run.
3 turn on the tractor, and wait 5 to 15 minutes till thermostat opens up. to flush the old stuff still in the block out.
4 shut the tractor down, and let rest of the stuff drain out.
5 shut drain valve
6 refill 50/50 mix.
7 turn tractor back on run for 5 to 15 minutes till thermostat kicks in.
8 top off 50/50 mix.
9 put radiator cap back on.
not sure if above way is correct or not, but its how i do it.
get an antifreeze tester, they are repetitively pretty cheap, there are gauges the sucks the mix up, and then there is a electrical way of testing, to test the antifreeze. to see were you high boil over temp, to low cold temp is.
Document Moved = newholland and ford tractors
my cheat link (dealer i bought the ford 555c TLB from) easier going through there site vs multi clicks to find the parts catalog on newhollands website
click link....
Vendor Catalogs サ Pat Kelly Equipment Co.
click ""New Holland Parts Catalog"" middle of page
"kaboom" spray can, its like a spray on bleach that foams up its for cleaning kitchen sink, bathtubs, toliets, etc... located in soap isle at walmart i do believe. have used it on radiator before on the allis, and also on the outside A/C unit radiator/fins, and on a 110v window a/c unit to clean the fins on it as well.
just spray it on wait a couple minutes, then a garden hose (without a nozzle) just a straight end garden hose to wash the stuff off. then possibly repeat one or 2 more times.
let everything dry before taking out into the dust. have noticed a change in allis and the a/c units in a cooler running temp.
i would double check the coolant pump, they do go bad. wear and tear, gunk build up inside of them. with overall effect of less GPM (gallons per minute) pumped, vs a new one.
you might consider, adjusting carb, if you need to mess around with the choke or have it out some or like
new spark plugs, new plug wires and new distributor cap/rotor, while it most likely not make a big difference on cooling problem directly.. it should revive the engine to run more efficient, its one of my yearly maintenance things. .
it is a system and not individual parts.
