Farmtrac 665 Power Steering Out
/ Farmtrac 665 Power Steering Out #1
mwest479
kubota L175
Need info on Farmtrac 665 , trouble shooting power steering.
/ Farmtrac 665 Power Steering Out #2
Don't know much about troubleshooting steering problems, but I'm curious as I have a 665. The steering pump shares the same reservoir with the transmission. The easy stuff would be ensuring plenty of fluid, filter not blocked. What it's doing? Can you describe the symptoms? If you jack the front-end up, do you get any wheel movement. Likely, the problem would be in the steering block, the pump or the cylinder. I have the service manual for the tractor and can post up some pics of the steering section if you need them.
This is a friends machine , trying to help. Don't have a manual. Claims dealer replaced an O- ring in steering & it worked for a time. Must be talking about the cylinder ?
/ Farmtrac 665 Power Steering Out #4
There's a front and back o-ring on the pump. There's a couple of o-rings in the steering unit and a lip ring that is installed with a special installer tool. And yes, the cylinder has several packing rings. If you find out what happens, keep me posted.
Thanks, if you have any trouble shooting info or pictures , all would be helpful. All of the hydraulics work , not the power steering.
/ Farmtrac 665 Power Steering Out #6
Check your PM.
I am assuming " PM " means pump motor ? Was advised by owner that hydr. work but very slow. Could be the pump. Have changed hydr. oil & filters. Does your manual explain how to bleed the system ?
/ Farmtrac 665 Power Steering Out #8
Sorry, I meant "PM" as in private message. I changed out my hydraulic/steering/trans fluid when I first got my tractor. There's no bleeding procedure, just run it for a few minutes. The trans, steering and hydraulic takes 80W-90 gear oil. There are a couple of flow knobs under the seat by the floor that might affect the lift arm speed. The steering pump and main pump are separated but share the same reservoir, which would explain why the other hydraulics are working. Your friend might have to get the steering pump tested, but the problem could be in the steering unit - lots of springs, checkvalves, and balls in there.
If you send me your email address, I have a couple of PDFs for you on the steering system.
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
2007 INTERNATIONAL 4300 SERVICE TRUCK (A66091)
2007 INTERNATIONAL...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2025 Pabreak 78in Rock Bucket Skid Steer Attachment (A66734)
2025 Pabreak 78in...
LIPPMANN HEAVY DUTY ROCK SORTER (A66734)
LIPPMANN HEAVY...
