Changing the ball joints on a Branson 4220
   / Changing the ball joints on a Branson 4220 #1
Bobandia
Lexington, ky
None
Last year replace the left side and last week I broke the right side trying to move a large stone.... dumb move... anyway.. I ordered the new kit that fixes both sides. I made the mistake of trying to remove the shroud to get better access to the joint and that resulted in a very damaged finger...didn't know it was under pressure. What is the best method of doing the change out. The arm lowered when I took off the nuts exposing the reservoir underneath. I could not figure out how to lift it back in place.
OK, so I managed to get the wheel back up, I see the bearings and how the trace is installed on the old cover. So I got the new one set and it does not seem to fit. Looks like the trace is larger on the new part. Unfortunately I did not see it was larger before I installed it. Cant seem to get it down far enough. Naturally there are no instructions and little that I can find on the web. I need someone out there to give me advice. Moving the tractor to a dealer is not a good option. Any other advice regarding this change out for this novice would be helpful.
2007 STERLING L9500 MIXER TRUCK (A50854)
2007 STERLING...
2025 LandHonor LHR-CIA200 200lb Cast Iron Anvil (A49461)
2025 LandHonor...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2010 POLARIS RANGER 4X4 4 SEATER UTV (A51222)
2010 POLARIS...
