Pressure test on Kioti 45 question
/ Pressure test on Kioti 45 question #1
nc redneck
Apex nc
Kioti Dk45SE Sold Kubota BX 2200 Sold Kubota B 3200 Loader WR Long 4 in 1
Question for you experts that do this for a living ( or did )
I have a kioti 45SE hst with woods loader. My plan is to plug gauge into 4 and 1 port. Warm tractor and fluid up. Put tractor at full throttle press 4 in 1 button and get results. I believe maximum setting is 2680 for my tractor.
I am not sure if 4 in 1 gets full pressure or should I go for loader port. 4 in 1 port is easy to see and seems like it would put less stress on tractor to test.
Is this a accurate test ?
/ Pressure test on Kioti 45 question #2
If you make up a QD with hyd gage, then you can plug it into any QD and operate the valve and read the pressure.
If you mount the hyd gage in a tee in the IN port of the FEL valve, then you can operate any valve and read the pressure.
You can also use it to troubleshoot and monitor your hyd system.
/ Pressure test on Kioti 45 question #3
Yes, that's fine, any port should show full pressure and you don't really need to be at full throttle either.
Here is a quick video I made showing how the test is done:
The color of the tractor makes no difference :)
/ Pressure test on Kioti 45 question #4
Just mount the hyd gage permanently in the in port of the FEL where you can see it at all times and you can sit in the seat and observe all the pressure you want for all hyd functions.
You can use it to troubleshoot your hyd system rather quickly by observing what pressure you have or don't have.
For a good pump test, you need a good flow meter.
With the hyd gage and flow meter and needle valve, you should be able to trouble shoot everything hyd on the tractor.
Thanks JJ and kennyd. Never hurts to check with experts first. I have learned a LOT from TBN.
Thanks
Scott
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
8ft. x 4ft. Lighted Sign (A65640)
8ft. x 4ft...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
2015 Kubota L6060 (A64126)
2015 Kubota L6060...
2011 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2011 GREAT DANE...
