2005 CASE IH DX25E
/ 2005 CASE IH DX25E #1
HABS1010
elie, manitoba
case ih dx25e
My 2005 has 586 hrs on it...tonight I was cutting grass and all of a sudden the tractor starting starving for fuel. it would go from 2500 rpm to 1000 rpm.
I let the tractor sit for about an hr and was able to start it up again. Sounds like it is getting too hot when starving for fuel. I clean out the fuel cap with a compressor, it was dirty but didn't work.
Any idea where I should start?
/ 2005 CASE IH DX25E #2
Mine was doing the same and then I discovered it had 2 fuel filters on it. The rear one was full of water, I changed it and problem was solved. In case you have trouble finding it my second (actually the first that fuel goes through) is located on the frame behind the left rear tire.
/ 2005 CASE IH DX25E #3
Where is the other filter? The DX25 is the same as my Kioti CS2410 and I only thought it had one filter.
/ 2005 CASE IH DX25E #5
Mine has one inside the left rear tire like I stated earlier (it's just an inline filter) and the other is located under the hood (it is a replaceable cartridge filter).
Lifts (A61567)
Lifts (A61567)
RoGator RG1100C (A63118)
RoGator RG1100C...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A62129)
2014 CATERPILLAR...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
