Tejas
IT looks good and solid. Can’t wait to see the finished pics. I think it may be too much for the 4 wheeler, but would like to hear your after actions report. Good luck.
Yep, I rotate or flip my blades very often in the Summer when roads are hard. If you put the blade into the bank position and set it with the front edge up along the right side of the machine you can rotate them standing up with the bolts about waist high. Makes it much easier. My moldboard is 14ft with two 7ft blades. I use 8"x15/16". They are very heavy. Our current machine (JD770G) ran 550 hrs before I had to replace the cutters.
Sorry for the hijack. Us Grader guys tend to wander......![]()
So THAT'S what happened to my mailbox...Sorry, I couldn't resist.![]()
IT looks good and solid. Can稚 wait to see the finished pics. I think it may be too much for the 4 wheeler, but would like to hear your after actions report. Good luck.
No worries. I can blade past a mailbox at 7mph and miss it by an inch. Since 1989 I've hit one.
Should I hold off on the sand?... not that it'll make that much of a difference... but if it's questionable if the wheeler can pull it...
