Loader bending metal on loader
/ bending metal on loader #21
This link (in the fuse theory) will either compress or stretch, I don't think it drops anything.
If in fact it is (in part) a fuse, highest forces are when the bucket is curled all the way down, precisely the condition where forces multiply, and may be a need to protect the bucket curl cylinders or other mounts. I suspect it is shaped this way to give the bucket more curl while protecting the components in this extended curl position. Seems strange that LS wouldn't state this (again, following the 'fuse' theory) so people know whats going on rather than guessing about their quality.
Ryan what was the bucket angle when you pushed on this cedar tree?
Theyre not stretching. Its a compression thing that happens when resisting uncurl. When they buckle there is a sudden uncurling. That would drop something. It would by definition be a heavy load and the buckle could be catalyzed be a jerk stop on lowering ... or a lift with a critical amt of load ... or a lift too high with load -- because the compression leverage increases with the degree of uncurl. ... Imagine using pallet forks. Keeping level as you raise.
larry
/ bending metal on loader #22
Just from looking at Sodo's picture, that dog legged link may be assembled upsidedown. It's concavity looks further from its pivot point than the pin it's designed to avoid(at the end of the boom)
/ bending metal on loader #23
They look like they are on my loader.
/ bending metal on loader #24
the dogleg is so the bucket can curl farther down (vertical), so the link reaches around that pin. At that moment it's a major force multiplier on the cylinders and their mounting.
Not sure anyone could use bucket forks in this vertical position (for example). In the 'level' position, the link is not subject to the force multiplication, it's ONLY when curled full vertical.
osley, do you have time to take pics of this link in several positions?
/ bending metal on loader #25
Hope it helps.
/ bending metal on loader #26
Presume you mean uncurled. As you raise a bucket - or forks especially - you uncurl to stay level. Leverage on the links naturally increases. Due to the close pin spacing on he bucket carrier there is compressive force on the links anytime uncurl is being resisted, regardless of position - worsens as uncurl progresses. See ozleys pics. It is a design issue.
larry
/ bending metal on loader #27
I would say the stright bracket is just a hair short. If back drigging with bucket down the cyd. rod well bend or the stright bracket goes over center and bend them as the picture shows.
/ bending metal on loader #28
The links are pulled when backdragging. All reports indicate they bend from being pushed on -- they buckle.
/ bending metal on loader #29
Iv'e put mine through just about everything imaginable, no issues. I have the LL3103 loader.
/ bending metal on loader #30
I agree in that the straight link might be the wrong size. Both of the links work together and alternate between compression and tension, opposing forces in each when being curled or uncurled by the hyd cylinders. So when curling, the curved link experiences compression and the straight link is in tension. The tension in the straight link should prevent the curved link from experiencing too much compression that will cause it to buckle. If the straight link is too short to hold tension, all of the force will be compression on the curved link.
/ bending metal on loader #31
Could the a loader pin be binding up for what ever reason causing the dog bone to bend and not pivot.
/ bending metal on loader #32
One would think the OP who has crinkled 3 sets would have noticed any existing bind during changeout.
/ bending metal on loader #34
Looks to me like there is a point in the dump cycle where if pressure is put on the bucket lip the cylinder rods dont compress but instead move downward causing the links to bend.
Hard to describe but I dont think that hydraulic pressure is doing it, but that mechanical pressure on the bucket is being transferred to the links.
Id get a new set of links, but use them as a template to make copies out of heavier materials, then swap in the upgrades if/when the factory design ones bend. I think the links are too weak, bad design.
/ bending metal on loader #35
I think with the cyl locked and back dragging, you are putting about a 5 to 1 , up to about a 10 to 1 mechanical force on the brackets, and causing them to bend.
You could perhaps brace up the sides of the brackets with some 1/2 in steel plate..
/ bending metal on loader #36
I compared my tractor dog legs to Ozley's pics and notice quite a difference with the cylinders fully open and closed. Ozley and the OP have the U5030 while mine is the XR3037HC. RyansLS has a 4041 and he just bent his dog legs in post#11. Mine are the ones with the forks (1 & 3). My dog legs seem to come back further (closer to the torque tube) than Ozley's when the cylinder is closed. The dog legs and the flats look the same but Ozley's cylinders appear to be longer. I haven't bent mine yet but now that 2 models (5030 & 4041) have I'll keep a closer watch on mine. Maybe it is a poor design.
/ bending metal on loader #37
larry
/ bending metal on loader #38
Could be they have not beefed them up enuf on the larger loaders.
/ bending metal on loader #39
I'm with Larry on this one. Total design flaw. That doesn't necessary mean wrong shape, can also mean wrong strength of material.
I would be very disappointed. And if LS isn't stepping up, then I'd be disappointed again. Replacing the bent links with the same product is meaningless.
/ bending metal on loader #40
I am not worried about it. I have done a lot of things with the loader over 3 years and never push on something I know that wouldn't move.
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
Engine (A59228)
Engine (A59228)
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
2005 Volvo VNL Truck, VIN # 4V4N19TG25N374995 (A61165)
2005 Volvo VNL...
LOT OF MISC SAWS (A62131)
LOT OF MISC SAWS...
