New Member - CK20 HST
   / New Member - CK20 HST #1
stallion143
Grand Rivers, KY
Kioti CK20HST
Hello to all! Just purchased my 2014 Kioti CK20 HST...Only have 8 hours on her as yet, but I've moved a lot of downed limbs & trees, bladed my driveway & purchased a set of pallet forks. This is my first tractor. I looked @ Mahindra, Kubota & Kioti. I believe I made the right choice. :thumbsup::thumbsup:
   / New Member - CK20 HST #2
Stallion143,
I think you will enjoy the tractor as well. I did a lot of research prior to my purchase and found the CK20S to be the overall best in its class. I love that it has just about the same foot print as the CS2410, but is much heavier. The new CK 2510 was not an option when I bought mine, but again, overall, I love my CK20S. I have pulled a heavy duty 4 foot brush cutter through 4' high weeds with as many saplings as weeds. I was able to to that in 3rd low (manual transmission) and could have went faster, but these mountains are a little to steep. You loose a little hp to the PTO with HST, but I would anticipate you being able to do the same. It will pull a five foot finish mower, but I use a 4 four foot for ease. I pull a single 14 inch turning plow with no problems. I pull a 6 foot drag disk. If you don't have the rear tires loaded, do so because it makes a big difference. Welcome to the forum and congrats on your Kioti.
   / New Member - CK20 HST #3
Congrats and welcome to the forum, I have over 800 hours on my CK20 HST (bought it used with 600 hrs on it). It has done what I needed it to do so far. Did you get the clamp on pallet forks? I have been thinking about getting a pair.
Enjoy
Rancho
   / New Member - CK20 HST #4
Welcome to TBN and The Pack!
Enjoy
Rancho
Rancho,
I thought about clamp-on forks, but I went with the pin-on ones. I can see my load better & generally when you use the clamp-on forks, you lose some lifting power because the forks are out farther and that reduces how much you can lift...Plus, my dealer gave me a good price on the ones I bought. $625.00
   / New Member - CK20 HST #7
hey Rancho, how much did you give for your tractor if you don't mind me asking.
   / New Member - CK20 HST #8
I paid 8500.00 for my CK20 HST with loader and finish mower and brush hog and box blade and extra bucket along with a 7x18 dual axle trailer. Plus the guy delivered it from south florida. I thought it was a pretty good deal.
Rancho
   / New Member - CK20 HST #9
850.00??!! I'd say that was an excellent steal! :)
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
