Score another one for the Tooth Bar
/ Score another one for the Tooth Bar #1
lakngulf
Lake Martin Alabama
Kioti CK30
Lots of discussion on the forum about the uses of a tooth bar on a FEL. I could not make it without mine. Yesterday, I wanted to plant a couple of rows of corn, at a small garden I have at the farm. After tilling, I needed to make rows, and it was HOT. I thought I might pass out if I used a hoe. So, enter the tooth bar on FEL, drive backwards, and waalaa, pick the row you want.
/ Score another one for the Tooth Bar #3
That is a really fantastic use for your tooth bar. I use mine all the time. Mine would not make rows like that - its got the same size teeth all the way across.
Mine has the same size all the way across as well. I was not looking for perfect rows, just something I could drop some fertilizer and corn into.
/ Score another one for the Tooth Bar #5
NO - I like the way your rows turned out. Mine come out closer and not near as deep.
