The start of a much needed paint job
/ The start of a much needed paint job #21
I would not advise using a sandblaster on assemblies with moving parts.
/ The start of a much needed paint job #22
/ The start of a much needed paint job #23
/ The start of a much needed paint job #24
You could get some paint stripper and then sand or sandblast the rusty parts.
/ The start of a much needed paint job #25
Stripping chemicals are pretty nasty, please take care when using them....and whatever you do please dispose of them correctly. I am no greenie, but that stuff is very nasty.
Take care with the wire brush as well....you can make a great deal of heat with that as well.
Keep the updates coming.
/ The start of a much needed paint job #26
Another comment on the wire wheel.....please wear safety glasses, a face shield, and heavy pants and gloves. I used one to strip the paint on a wire pallet rack type shelving unit and it would occasionally throw a wire which would stick through my pants. I look forward to the "after" pics.
Yes I have been wearing all the safety items listed and I am trying to see about sand blasting I want to get my own to have for other projects ( 1981 kubota b7100 loader backhoe) and yes I will try paint stripper at some point will it really save me that much more time? Also question new kubota orange or old
/ The start of a much needed paint job #28
The Harbor freight pressure blasters are fairly cheap and work well for the money. There are a lot better ones out there but for the price it will allow you to do what you want to do without a large investment. If you blast the tractor don't do assemblies where sand could get into bearings, housings, etc.... That is very good advise as sand will get in places you think are well sealed and cause havoc. The sheet metal on the older tractors is pretty heavy duty and blasts easily. I have done several machines including a Kubota similar to yours without issue. If you you are blasting it, keep moving and use something like Black Beauty, not "sand." It will cut MUCH faster and you won't have to worry about warping the metal as long as you are moving your stream. Speaking of "Sand" - use a OSHA approved mask when blasting - in short, the airborne silica is VERY bad for you and using something like Black beauty further minimizes this.
I also don't know what kind of compressor you have but blasting is VERY air intensive. A small single stage compressor is going to work and work hard to blast. I like using screw compressors but for the money a good two stage will serve you well. Worse case rent a tow behind for a day and have a lot of sand on hand. You can blast a LOT of stuff in short order!
Good luck and have fun!
/ The start of a much needed paint job #29
Pictures....keep the pictures coming.
/ The start of a much needed paint job #30
For small projects where you have the time, a small blaster will work. Your biggest issues will be air supply/air quality, but if you are not on a tight timeline you can make it work. As mentioned, a blaster can stress out a small compressor and moisture will make you pull your hair out, but there are ways to improve these two problems if you want to do them. We started out with a small pot, but soon realized (with the amount of blasting we do) it wasn't getting the job done. We rented a larger system a few times before buying our own (200 CPM compressor and 350 lbs pot). If time/aggravation are concerns, perhaps renting is a better option.
We use duck tape around the sensitive areas to help keep the sand out. It won't take a direct hit from the blaster, so you have to keep some distance. We have used Black Beauty in our blasting cabinet, but in the pot we use 35-65 blasting sand.
/ The start of a much needed paint job #31
Double Post.
/ The start of a much needed paint job #33
Paint stripper works pretty good. You have to time when you scrape the paint right, too soon it won't work, and too late the paint starts to harden again.
These sanblasters don't work too bad. Sears.com
Alright I have not touched this thread or tractor for a month I haven't had the time sadly, however I get out of school on June 24th and I plan on getting some paint and primer and brushing it on . I just need some help what do you restorers reccomend for paint is majic paint any good or should I just go with the kubota paint.
Also I finally got some pics of this little orange beast 33 year old
/ The start of a much needed paint job #35
If you are going to go through all that work why not spray it? You can get a paint gun for not a whole lot of $$$$$$.
I'm not so good with the gun and also it's a farm finish for me not a full 4shorts restoration
/ The start of a much needed paint job #37
I've used Majic paints. I think it will be fine.
/ The start of a much needed paint job #38
I personally would disagree. (sorry GPintheMitten) I have not had much luck with the Majic paints. There is several threads on here about them if you are interested. I personally prefer the Kubota paint but there is a lot of good paints out there.
Some of the better paints will "level" out pretty well even if you brush them but the spray will do a better job. Honestly not too hard especially if you are not real worried about the finish (will save you hours)
Good luck
I personally would disagree. (sorry GPintheMitten) I have not had much luck with the Majic paints. There is several threads on here about them if you are interested. I personally prefer the Kubota paint but there is a lot of good paints out there. Some of the better paints will "level" out pretty well even if you brush them but the spray will do a better job. Honestly not too hard especially if you are not real worried about the finish (will save you hours) Good luck
Okay I will look around at 90 bucks a gallon it would be nice if majic was good but if it's the best .....
/ The start of a much needed paint job #40
Check online for a better price and really any quality auto paint will work. Valspar made some decent paint for the price (TSC used to carry it) and I am told some other retailers are carrying it - maybe someone can chime in and give you some idea where.
Good luck!
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2016 Ford E-350 Passenger Bus (A61568)
2016 Ford E-350...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
