   / Your last generator Maintenance Run
Bay Area Air Quality Management District or BAQMD has jurisdiction and also collects the yearly fee for burning through a 100 gallons of diesel annually.
One of the old engineers asked my why I let it bug me... he said all the new regs is what keeps us working...
Told him I just don't like to see waste... no matter who is footing the bill.
Sad.... doubly so, as a lot of N. America follows Ca policy some time later....
True enough, it's not just the EPA that likes these make-work programs.....
Rgds, D.
   / Your last generator Maintenance Run #252
We are installing two new 4 MW generators at a major NYC hospital. The old ones are 60 years old. I can't imagine the government mandating that they can't be run in 20 years because they don't meet emissions. But you never know with that city government.
I thought standby gensets didnt have to meet tier 4, us that true?
   / Your last generator Maintenance Run #253
It has not quite come to that...
What happened is we are now required to pay for a permit to operate each year... due to the age/emission output testing and maintenance operations is limited and subject to inspection.
Should we need/decide to be replace we must install a more up to date unit AND our genset may not be installed anywhere in the district as it has been deemed non-compliant...
Gas Steam Boilers are already on their radar too...
   / Your last generator Maintenance Run #254
Date: 6/1/14
Generator: Multiquip 60KW
Activity: Exercised the generator with a load, added 5 gallons of AMSOIL, changed fuel filter, oil filter, changed air filter, drained cleaned radiator added fresh coolant. Two new batteries, 4 new tires, replaced brake lights with LED lights. Ordered a custom cover.
Final Fueling notes: Added 100 gallons of fuel.
Maintenance notes (Done, or Required): Will change belts, battery cables.
   / Your last generator Maintenance Run #255
Date: 6/1/14
Wow! What task do you use that generator for?
   / Your last generator Maintenance Run #257
ive used the multiquip ultra quiet trailer mounted units in the past. The size of a small semi, and you can hardly tell its running. We used them to power movie sets.... years ago
   / Your last generator Maintenance Run #258
Multiquip has very good generators... super quiet and efficient and most are trailer mounted with extended run tanks.
Rented them before for Health Fairs and similar.
I saw some Multiquips running at a Fair last weekend. There's another brand I've seen too, in the same application, name escapes me at the moment - but I do recall they too were originally develloped for movie sets - makes sense.
Used at these Fair sites, the ones I've seen likely weren't even half-loaded to capacity - but still, they are impressively quiet - most people wouldn't even suspect that they are diesel driven.
One more item for the What to Do with Lottery Winnings list..... :thumbsup:
Rgds, D.
   / Your last generator Maintenance Run #260
My coworkers husband works for Multiquip...
If I had some lottery winnings I would be putting in my order!
2018 Ford Transit 150 Cargo Van (A56858)
2018 Ford Transit...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
New/Unused Quick Attach Bale Spear (A57453)
New/Unused Quick...
Garbage Truck (A59230)
Detector Generator (A57149)
Detector Generator...
