Greasing Front Axle Support
/ Greasing Front Axle Support #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
On my L3200HST 4WD the manual says to remove the breather plug when greasing the front axle support. The plug is one of the square head bolts and I can't get it out. I seem to recall someone saying that the axle could be under pressure. Is that possible? Or should I just squirt some bolt remover in there to try to loosen it up to remove it? I need to finish my grease job.
/ Greasing Front Axle Support #2
It's not under pressure the bolt is just a real bear to gt out the first time.
/ Greasing Front Axle Support #3
Agree here.
I've tried removing these on several L models.
It's a 7mm square 4 point head pipe plug and they are tight.
Nobody I can find offers a 7mm 4 or 8 point socket.Mac Tools offers a kind of universal socket that may fit but I've not tried one.
I've tried a 7mm open end wrench,but the plug is just too tight and the jaws just want to spread or round off the head.
I've managed to get then out with 4" vise grips on an angle and the plug was still useable.
I wonder how the Kubota techs do it?
/ Greasing Front Axle Support #4
I have a L3430 with the plug. Why does the plug need to be removed? I have put grease in the only zerk I have found. The grease seemed to go in ok. What am l missing?
/ Greasing Front Axle Support #5
Just guessing here but could the seals blow out if no relief was provided??:confused3:
I read my manual and it said to remove the plug however no explanation why.
/ Greasing Front Axle Support #6
Agree here.
Are you sure it's not 9/32"? If so, maybe this would work.
http://ebay.com/itm/190740977336?cmd=VIDESC&gxo=true
/ Greasing Front Axle Support #7
You are missing the 2nd zerk.. there are 2.. one in front and one in back.. the one in front needs the plug removed. I used a 10 inch adjustable wrench. Apply grease to the front zerk until you see grease start to move out of the the plug hole. Reinstall the plug. On the zerk on the back side of the front axle pivot , pump 2 pumps into the zerk, making sure it "took" the grease and then stop. This grease goes inside the axle housing after lubing the pivot point. So DO NOT keep on pumping. Just 2 shots every 50 hours and stop.
/ Greasing Front Axle Support #8
Thanks for the information James. TBN is almost always a great source for this type expertise. I'll follow your recommendation.
/ Greasing Front Axle Support #9
You are missing the 2nd zerk.. there are 2.. one in front and one in back. On the zerk on the back side of the front axle pivot , pump 2 pumps into the zerk, making sure it "took" the grease and then stop. This grease goes inside the axle housing after lubing the pivot point. So DO NOT keep on pumping. Just 2 shots every 50 hours and stop.
This back zerk drives me nuts. Does anyone know where the excess grease goes? Philip.
/ Greasing Front Axle Support #11
Your guess is correct. You will blow out the seal if you do not remove the plug when greasing.
/ Greasing Front Axle Support #12
/ Greasing Front Axle Support #13
Good thought Mike!
I hadn't thought about a fractional size that would work.
I also never noticed a 9/32" square socket before.
9/32" x 25.4mm/inch=7.14mm,a tad loose but might just work OK.
Thanks.
Why not just use a Crescent wrench?
I tried a crescent wrench...a 7mm seemed to be the closest fit, but it is really stuck on there and I started rounding the corners so I thought I would try a 4 or 8 point socket...but can't seem to find one. I got a feeling my best bet is going to be a set of vise grips and hopefully(?) replacing the stupid plug with a regular bolt of some type.
/ Greasing Front Axle Support #15
The threads will be metric.. Did you try a 12 point socket, they fit square headed bolts. I actually used a 10 inch crescent wrench held up real tight down in the section of the jaws closest to the handle. I got it to break loose.. One problem is probably the paint. I wonder if just a few seconds with a propane torch on the bolt would help. Maybe a Kroil soak for a few days.. put a drop on each day?
/ Greasing Front Axle Support #16
Crescent wrench=adjustable wrench. Adjust it tight as possible, plug as far in the jaws as possible. I would think you should be able break it loose.
/ Greasing Front Axle Support #17
I guess I'm lucky. I've never had a problem removing the breather plug on my L3830. I use a small adjustable wrench.
And thanks for the info on where the grease goes from the rear zerk.
/ Greasing Front Axle Support #18
Does a L3800 have this same setup? I don't remember reading about it in my manual.
/ Greasing Front Axle Support #20
That makes two of us :-( I haven't seen anything in my WSM about one, nor could I find one yesterday when looking for it after reading about it on here. I'm generally **** about greasing; heck, I loose sleep at night wondering if I missed one or didn't get the right amount of grease in.
I had read in the manual about being sure to grease the TWO zerks on the hydro-pedal. Guess what? There are THREE zerks on mine. I just found a third one after 5 years. I'm hoping that someone can tell me exactly where the two on the front pivot point is located.
INOP/NON-RUNNING 2000 Sterling L9500 Cab/Chassis Series Truck, VIN # 2FZXEWYB3YAG90325 (A61165)
INOP/NON-RUNNING...
Steel Concrete Wall Panels (A61166)
Steel Concrete...
(2) 460/85R42 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R42...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A62129)
2020 CATERPILLAR...
2016 John Deere HPX Gator 4x4 Gas Utility Cart (A61567)
2016 John Deere...
