engine oil
/ engine oil #1
missedshot
Quitman, TX
CaseIH 95C
have a new 95C and would like to know if these engines perform well or not when fed Shell T6 or stick to case brand of oil?
/ engine oil #2
I have always used one of the Shell Rotella oils in all my diesels. I would advise that if you switch from the Case oil, you should go with a larger name brand such as Shell Rotella or Chevron Delo and you will be fine.
/ engine oil #3
Case doesn't refine oil. One of the major manufacturers does it for them.
Like Tom said, just use a good name brand diesel rated oil and you'll be fine.
/ engine oil #4
G'day I have been told that Fuch's supplies the oil for initial fill to alot of manufacturers case included, a grren machine owner took alot of convincing that JD did not refine their own oil until I showed him the small fuchs logo on the drum.
Jon
Giyi PG72 QA 72" Grapple (A60463)
Giyi PG72 QA 72"...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2015 Komatsu HM400-3 (A60352)
2015 Komatsu...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
DEUTZ MARATHON...
1999 John Deere 7810 (A60462)
1999 John Deere...
