Save money by spending money?
   / Save money by spending money? #1
swick1
WV
John Deere 1026R
Here's my new milling machine which was built around 1947 and rebuilt at some point between now and then according to the tag on the side. I started building my own attachments to save money but I've spent an awful lot on tools to do that :)
Securing it to the trailer was kind of hard to figure out. I ran the straps first. The left front strap wraps around the right side of the ram then connects to the left rear of the trailer. The right strap does the same thing to prevent it from wanting to twist the machine around. There was nothing to attach to on the base casting so I wrapped a chain around it as tight as possible and used my three remaining chains to secure it at three points (2 in the back, 1 in the front). It rode very well coming home. The motor in front of it is part of a 3 to 1 phase converter.
I haven't moved it into the building yet because I don't have an engine hoist and none of the auto parts places around here will rent one. I would hang it from the ceiling but it's an awful lot of weight to try that! I don't want to spend more than $50 to move it. Does anyone know how much the base casting weighs? I thought about disassembling the head, ram, and table then trying to move it in pieces.
Another idea I had was to build a heavy duty pallet out of 2x4's and 8 lawnmower wheels. I would remove the gate and strap the pallet to the back of the trailer so it couldn't roll. Then I would use the tractor to slide the mill off the back. When it got near its tipping point on the edge of the trailer i would hook my pallet fork frame to the machine and strap it to securely, then carefully finish pulling it onto the pallet (about 2" drop)
   / Save money by spending money? #2
How did you get it on the trailer?
   / Save money by spending money? #3
Ken from bolt on hooks put one in his basement and has a thread on it.
   / Save money by spending money? #4
Is the ceiling to your shop still open ?
If so, how about placing some heavy lumber perpendicular to the rafters, to distribute the load across say 4 rafters ?
That might not get you exactly where you want it, but it would be off the trailer.
Rgds, D.
   / Save money by spending money? #6
No neighbors with a large tractor?
   / Save money by spending money? #7
Plywood an soap works
   / Save money by spending money? #8
the head should come off with 4 bolts, that would help some, the weight should be under one tone, even if one can get it under a solid tree, and lift it off on to a skid of some type, and pull it slowly to the shop,
(I don't know if the little compact tractor if keep up close to the tractor wood lift it enough to shuffle it across the floor or not),
in the shop one could put up a beam and supports under the beam just for removal of the mill, lift drive out form under and lower, remove the beam later,
I did that once with a walkin freezer roof that was complete with all the condenser and evaporator, ( in this case, I had to lift swing and set down,) and made a small beam that would do that,
   / Save money by spending money? #9
Is the motor on the trailer for a three phase roto converter?
Yeah. I haven't inspected it yet, but it's basically a box of capacitors, a motor, and a disconnect with 3 fuses.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2008 CAT 287C (A50854)
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
71068 (A49346)
71068 (A49346)
