Super Blower
/ Super Blower #1
r2d2jim
Chesaning, MI
AC D-17
Our home is surrounded on three side with woods. In the fall the lawn gets covered with leaves. I am getting older and tired of raking. I have been looking for a big leaf blower to use. Couldn't find any that I liked or wanted to afford. So I built my own!! I picked up a used JD 6000 forage blower for $400 and modified it to make my "Super Blower". I removed everything on the blower except the fan, frame, wheels and hitch. I recycled some of the sheet metal to cover the fan inlet and add extra support. I had to cut the frame so that I could rotate the blower outlet to 90 degrees +- and used a piece of 2" square tubing in rebuilding the frame around the outlet. I added a platform on the back and added two pics of 4" PVC for use in carrying a rake, fork etc. The blower spins at 1000 rpm and will blow my hat off at 30 feet. I think I am going to like this new toy!! To date I have less than $500 invested!
/ Super Blower #2
Looks very nice. I had an old chopper that I was going to make a blower or snow blower (the fan portion) with it. Never got "round to it". I bet that would be handy for burning the big brush piles, or at least helping getting them going.
/ Super Blower #3
Looks great and not too much money in it either.:thumbsup:
My only concern would be turning too sharp with the driveline, I would have built this with a 3ph setup for this reason.
/ Super Blower #4
That is very cool and a great build. What exactly is a forage blower so I can start looking for one at a auction ? I would think they would be used for burning brush.
It is very similar in my quick attach front end sickle mower. Just made out of junk and a lot of hard work. It will be my next project, if I can find one.
Great build and thanks for posting it
Scott
/ Super Blower
Yes, that was a consideration and still is. I thought that I would try the trailer type this fall and see how it works. If it is a major problem I'll probably change it over to a 3 point. I did try it around the yard and didn't seem to be much of a problem as long as I didn't turn real sharp. I use a compact 1140 MF tractor with turf tires to operate the blower. Weight on the 3 point was one reason I kept it as a trailer. Also it is easier to drop a pin in the hitch and go compared to hooking up a 3 point every time I want to move it. We'll see how things evolve!!
/ Super Blower
A forage blower is used by live stock owners to fill upright silos. It will blow chopped corn or grass 60 Ft. straight up an 8"pipe at a very rapid rate. If you look for one, get one designed to turn at 1000 RPM provided you have a tractor with a 1000 RPM PTO. Otherwise you can use one rated for 540 RPM, standard on most tractors. It just won't blow as strong. Good luck!
Scott
View attachment 378450View attachment 378451
/ Super Blower #8
We have an old New Holland 25 Forage Blower here on the farm we can't even give away. I've thought about doing something like this with it. Nice job.
/ Super Blower #10
I could see one IMatch ready to put to work. I should start looking for similar forage blowers and build my own.
/ Super Blower
Maybe sometime in the future as there isn't much to try it on now. And then I have to figure out how to upload a video!!!
/ Super Blower #12
I wished I'd have seen this last fall. There was an old blower in a pile of junk behind the barn from previous owners that I sent to scrap. A great idea if nothing more than "just 'cause I can"
Nice build
/ Super Blower #13
I built one of these 2 years ago. Mine is 540. I think I'm gonna look for a bigger tractor or install a gear box to speed it up a bit mine works but doesn't blow as hard as it should. But I need to figure out how much faster I can go before it becomes a negative air.
/ Super Blower #14
Add a smaller fan to the opening to help feed the ambient air into the blower? Kind of like compound turbos on a diesel. Could be either belt drive off the PTO or possibly 12v - ford Taurus fans move lots of air.
/ Super Blower
Great Idea. I'll keep that in mind!!!! My friend owns a salvage yard. I'll tell him to find me one. Any specific year??
/ Super Blower
Tried out the blower today and it works great. What used to take me 2 hours raking now takes me about 20 minutes using the "Super Blower". It will blow leaves 50+ ft. I blew them into a large pile and then hauled them away. I use engine speed to control the distance I want to blow the leaves. It is kinda fun to use.
213087 (A64276)
213087 (A64276)
15-19.5 Tire and Wheel (A68134)
15-19.5 Tire and...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2017 Ford F-150...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
