Need Help!
/ Need Help! #1
sampey3514
Goldonna , Louisiana
Mahindra 3016
I have a mahindra 3016 manual shift 4x4 tractor- when you engage the PTO, the shaft doesnt turn. Its seems to be going into gear because you cant turn the shaft when you engage the pto. I have checked the fuse and its good . I was wondering could it be a pto solnoid switch . Any ideas???
/ Need Help! #2
You may want to edit your post so the title is more descriptive, like pto not engaging or something like that.
/ Need Help! #4
Is it the pto splined shaft on the tractor or the attached implement shaft not running? If its the implement shaft you may have a busted shear bolt.
/ Need Help! #5
Sounds like the shear bolt. Have to line up the holes and put one in.
/ Need Help!
It is the PTO shaft coming out the tractor. If you take all the PTO out of gear you can spin it with one hand , put it in gear and you cant turn it . Like its going in gear but whenyou try to use it nothing turns>
