Ford 1710
   / Ford 1710 #1
Great Falls, MT
Ford 1710
Hey guys I have the opportunity to buy a nice Ford 1710 tractor with only 520 hours on it from my boss who's selling his house. He'll sell it to me for 2k, this will be my first tractor. It has a front end loader and 4 or 5, 3 point hitch attachments. The back tires have plenty of tred left but the side walls are starting to crack and the valve is rusted out and leaking. It will need two new back tires, or can I just put a tube in them?
Also its been stored outside for at least 5-6 years that I know of. I'm sure it will need the oil and trans fluid and filter changed as its been sitting for the last few years unused. I'm also going to grease all the certs. I started it the other day and it fired right up. Is there anything else I should know about this tractor? Will it be able to move dirt to help build up a small dam wall (5ft) thats starting to deteriorate?
Thanks guys!
   / Ford 1710 #2
2K, you find yourself a "diamond in the rough". It is a total steal in broad daylight. Congrats. It is a great tractor. it has much similarity to my 1700. Can search the forum for 1700 and you will find a ton of good info. It'll do all you asked above , may be slow on dam project. remember, it is not a dozer. That will be a great early or late fall. You will not regret this great purchase. :)
   / Ford 1710 #4
I'd jump all over that!
Joe
Sent from my XT907 using TractorByNet
   / Ford 1710
Awesome! I'm glad to hear it's a good deal. So what can I do about the dry rotting tires?
   / Ford 1710 #6
Nothing you can't do to repair the tire. I'd just use the heck out of it. It is such a fantastic deal that you come way ahead even with two new tires or even second hand. I would not worry about it at all. Actually looking at the pic can't see the tire in bad shape at all. might take some close up picture for a visual eval. what you have would easily go around 8-10 k so you got room to spend a few more bucks. I know guys here same with me would salivate on a deal like that :) now , does the lift, loader, pto and gears work?
JC,
   / Ford 1710
JC,
Yes everything works fine, there looks to be some oil residue where it was leaking out underneath at some point. I'll take a picture. The tires are in bad shape. I mean it still has PLENTY of tred but the back tire you can't see won't hold air and the valve stem is rusted out. When I try to fill it with air it squirts out some kind of clear liquid and it goes flat. Can I put a tube in there? Thanks guys, I'm super excited about the tractor!!
   / Ford 1710
I have a few more questions maybe you guys can help me out with. So the 1710 came in two different transmission versions. I think mine is the synchro-mesh because it has the 4 gears on bottom and steering stem shifter. Is this the better version? Do I need to come to a complete stop to go from F to R? How about shifting gears whats the best way when using the FEL?
   / Ford 1710 #9
Good deal on a good rig! Order yourself at least an owners manual the minute you hand over the cash.
Jim
   / Ford 1710 #10
The Synchromesh is, in my opinion, the better transmission. It has the range selector on the hump and the shuttle shift on the column.
The stick on the bottom is your range selector. The tractor needs to come to a complete stop to change ranges. Depress your clutch pedal fully, choose your range, then use the shuttle.
The stick on the column is the shuttle shift. It can be shifted while in full motion or stationary, provided the clutch is used.
Joe
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
