Which one to buy.......
/ Which one to buy....... #1
debo1107
Corpus Christi
Dixie
New to this forum. And am looking for a little help. I have a home on 1 acre and the 2 month old husqvarna 54" riding mower i purchased is not doing the job very well. Serious problem with mud accumalating on the deck and very slow. Ive decided to go with a zero turn and have narrowed it down to 2 dixie chopper models. Im looking at a Zee 2 54" with a brigs motor for $4,650 and a Magnum 44" with the kawasaki motor for 4,850. I know that the magnum is more commercial duty than the zee but am unsure weather about the smaller size. Can anyone give me some insight on which of these 2 would be better for my application? Any help would be appreciated.
/ Which one to buy....... #2
I do not have an answer but would suggest posting a pic of your yard so that those who know can see what your dealing with in order to give you a better educated opinion.
Best
Chris
i dont have any pics but its flat south texas clay. I do not have grass in the back yard so pretty much all weeds.
/ Which one to buy....... #4
I'd go for the heavier duty model with the Kawasaki motor every time, even though its cutting width is 10" less, especially with only 1 acre to cut. Either of those mowers will make short work out of 1 acre.
Thanks. That's what i am leaning towards. Just wanted to see what some other opinions out there were.
/ Which one to buy....... #6
I don't know which Briggs motor is in the Zee 2. I've got a John Deere GT235e garden tractor with a Briggs Vanguard motor, which is Briggs' commercial motor and it's a very good motor. But I think the Kawasaki is just a better engine altogether.
I think the Magnum 44" with the Kawasaki motor would be the better choice in your situation.
/ Which one to buy....... #7
I've got a 42" Toro ZR series and the 22 hp V-twin Kawasaki engine rocks. I wound up welding on a round stock bar to the metal frame that holds the bagging system to accept bar weights and then added 50 pounds for better traction. No matter what I've done, the engine has never bogged down. Most recently, I was using the mower to "brush hog" up to 1/2" five and six foot tall saplings. While not completely efficient at this due to a lack of weight in the front, the engine turned everything into mulch. I did have one sapling mess up a parking paul on one side, but I was able to easily sort it.
Anyway, all to say I'm super impressed with the Kawasaki 22 hp engine and the hydrostatic drives it is connected to.
/ Which one to buy....... #8
What ever mower you get make sure you get the Kawasaki motor. I have Toro SS 5060 with the Kawi, great engine and great mower.
Thanks for all the input. Im going to pick up the DC Magnum with the Kawasaki tomorrow!
It has the FS651V kawasaki motor. Is this the good one?
/ Which one to buy....... #11
That is the same engine series as mine. The intake may look different because some OEM's are now using a Donaldson two stage intake system. If not, you'll have two finger screws to pop off to get at an oval-style air filter like the image below. If it is an engine from my mower's era, then, the cover just flips up, no screws whatsoever to get at the air filter. This matters because in dusty areas, you can use compressed air to clean off the air filter to extend its life.
A really cool thing is that this engine is super easy to winterize in that you pull the wire off of the the bottom of the carb bowl, unscrew the bolt with your hands, dump the bowl, reinstall everything, and the engine is winterized.
Make sure you get the hour meter.
TAKEUCHI TS50R SKID STEER (A62129)
TAKEUCHI TS50R...
New/Unused CFG Industrial MH12RX Mini Excavator (A61166)
New/Unused CFG...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
2018 EH Wachs Trav L Vac Hydro Vacuum Excavator Trailer (A61567)
2018 EH Wachs Trav...
Utility Cart (A59231)
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61567)
2019 Toro...
