Bx1500 brakes stuck
/ Bx1500 brakes stuck #1
Kaptain
This BX1500 is about 12 years old. Set the brake the other day and now it is frozen on. Pedal moves freely and lock lever operates normally locking and unlocking the pedal. Any one with knowledge of this system, suggestions or similar problem? Thanks for the help!
/ Bx1500 brakes stuck #2
There is an adjustment rod/ link going from the pedal to a lever back just above the right axle. The rod is pinned to this lever. ... Does the rod move back and forth as you operate the pedal? Is the rod still connected to the lever?
All the linkage appears to be connected and normal.
/ Bx1500 brakes stuck #4
Did you try putting it in reverse and backing up? Does the pedal come back up to its normal released position? It could be that your brake friction and pressure plate disks are worn beyond their limits and it allowed the balls in the brake cam plate(s) to ramp up out of their recesses, wedging the brakes on.
Pull up a parts breakdown of the brake assembly on Messick's and you'll see what I'm talking about.
Pedal does work and feel normal.
Don't believe that it could be excessive wear as brakes are so rarely used. Thanks
It seemed to be an issue of my tranny fluid being low. Tried coasting downhill in neutral and wheels didn't lock up as it did in-gear. Added fluid and now all seems normal. Hope no permanent damage. Thanks to everyone for the help!
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
2003 John Deere 567 Megawide (A64126)
2003 John Deere...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
