Hydraulic cooler
/ Hydraulic cooler #1
brincker
Mechanicsburg, IL
bobcat CT 230
I have ct230 that is leaking fluid from the hydraulic cooler. anyone know how much it is replace? is it pricey for the dealer to fix it.
/ Hydraulic cooler #2
I assume you are past warranty?
/ Hydraulic cooler #3
Some of the CT's had a history of cooler failures
It would not hurt to ask if Bobcat will stand behind it
/ Hydraulic cooler #4
Welcome to TBN!
Dealer fixes aren't on the cheap side, due to labor rates. What year tractor, how many hours on it, any pics or fuller description of where the leak is? Under warranty or not?
/ Hydraulic cooler #5
If warranty is not an option, you might want to consider trying one of the Kioti dealers (or ordering on line). Michigan Iron has them on their website for $193.55. Its part number T2185-37011.
Link
Many people had problems with them ~3 years ago and there were some old threads here on TBN about the subject. Many were replaced under warranty. Given it's two bolts and two fittings, it should be a pretty easy job to swap one out.
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2019 GALYEAN...
832647 (A61165)
832647 (A61165)
2000 Sterling L7501 T/A Drill Rig Truck (A60352)
2000 Sterling...
Blue Diamond 103709 (A53317)
Blue Diamond...
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
