Tractor weight vs. finish mowing
/ Tractor weight vs. finish mowing #1
mo1
SW Missouri
JD 5075E
I will shortly be moving to about a dozen-acre piece of property with about an acre of "horsey" areas that need rough cut, eventually about two acres of mowed-weeds lawn, a good-sized garden I'll till with a borrowed 3 pt tiller and the rest is trees, some of which I might clear out. I got a lot of good advice about what kind of a tractor to get on a previous thread and I thank you all for the input. The one question I came up with that I can't really find an answer to despite lots of searching on TBN is how heavy of a tractor is too heavy for finish mowing? The reason I ask is that the weight of compact 4wd tractors in the 25ish PTO HP range I am looking at range from about 1750 pounds (Kubota B series) to over 3000 pounds (Kioti CK series) for the tractor alone. I'll be getting R3s on whatever tractor I do buy as it will be required to do all of the tasks mentioned above and I'll not be doing any major ag work to require R1s. I'll preemptively strike and say a ZTR in addition to a tractor isn't an option for several very good reasons including my wife's input. I'll also be getting a loader and likely running a 72" rear finish mower as well, so add about 1000 pounds to the tractor weight. I'd probably leave the loader on to act as a counterweight to the mower on a tractor this little based on experience with larger tractors with heavier 3 pt implements. (I would scoop up a bucketful of dirt in the loader to counterweight a 3000 pound 3 pt field cultivator on a ~7000 pound 80 hp utility tractor to be able to still steer in turns when I raised the cultivator off the ground.)
So, how heavy of a tractor have you guys used and not had bad problems with lawn rutting or how heavy was "too heavy" for you for finish mowing? Mind you the lawn is mowed weeds right now and eventually I'd like to get that to "more grass than weeds" but it's never going to be a golf course-quality sodded lawn and I FULLY accept that. I also very well am aware of the "buy the next size up" advice based on my family's experience with tractors. My Dad "graduated" from a ~50 engine HP tractor to a 125 hp unit and went through another 80 hp unit somebody got a good deal on in the process. I want to know if buying that next size up is going to cause me any additional issues other than financial :D
/ Tractor weight vs. finish mowing #2
I have mowed for years with a Kioti DK 35 ( I take the loader off) and 7' rear finish mower .
Works fine.
/ Tractor weight vs. finish mowing #3
Recently I used my LS P7010 (about 10,000 pounds with loader and loaded tires) to mow my back pasture that has some type of yellow flowering weed that I wanted to clip off. I had the skids sliding on the ground and it still was over 4" high. It took me better than an hour and I didn't get behind some trees very well. 3 days later all the weeds were flowering again so I just took my Ferris ZTR over, raised the deck to 3" to get above some of the rocks and cut it including the stuff behind the trees in 45 minutes. The ZTR did a much better job and took less time, no rutting either. It would have to be a very rough area for not being able to cut with a mower. If it can be cut with a tractor and finish mower it can be cut with a lawn mower.
I have 11 1/4 acres and routinely mow about 6 acres of it in lawn. The rest is in cow pasture and creek and does occasionally get the mower treatment
I wouldn't try to mow an area where saplings had been growing and were cut off with a bush hog as they could damage the shafts but any grass or weeds is fair game.
/ Tractor weight vs. finish mowing #4
I went thru a similar issue. I have a golf fairway type lawn. No weeds.. subdivision type. Recently, replaced a 1100 lb simplicity with a K B3350 at about 2500 lb with 60" mmm and rear PTO catcher. Wanted cab and 4 WD for short 25 degree hill . Also have K L39 @7000lbs for several years. Driving L39 and turning noticable damages the grass that takes a month or so to recover. Have cut with the B just 3 times. (New this winter) Straight ways are fine. Turning in 2wd , occasionally mares the sod. Learning to turn shallower. Doing my hill, up and down, the 4wd does fine for traction, but I need to return to 2wd to avoid serious damage..2-3 month growth repair. Its a plow-forward-dig of the front tires kind of damage. For either machine, if ground is recently wet, grid imprinting occurs. Have turf tires on both. My Simplicity rarely caused grass damage except when I lost traction with 2 WD. Thought the 4wd and cab would fix everything. I spent a lot of money to trade problems. Unloaded air pressure in rear tires helped. But in the WINTER with the cab, I'm much happier!
So you're saying try to keep it under 2500 pounds? How do you like that B3350 by the way, that was one model on my list.
/ Tractor weight vs. finish mowing #6
Unless you live in a bog, I wouldn't worry about it. I use a 6' finish mower behind my Ford 2600. That old tractor weighs about 3500#, and it doesn't have turf tires. It's never been a problem.
/ Tractor weight vs. finish mowing #7
Bigger tractors typically have bigger tires too. So that said, I doubt you would see an appreciable difference in anything the sizes you mentioned.
And take the loader off. Rfm's are lighter and in close. Shouldn't have a bit of trouble when raised. When mowing though, the weight is on the ground, and the fel adds a bunch of weight to the small front tires. And that makes it easy to cause damage to a lawn.
/ Tractor weight vs. finish mowing #8
Moved for years with an MF 1045 roughly 3500 lbs, ag tires, plus loader(sometime removed) and an woods rm90. If it was wet there were issues, and tight turns there were issues, other than that it aw fine especially for pastures
/ Tractor weight vs. finish mowing #9
Ld1, thanks, I have released the bucket but I cut the grass with the loader still on. I'll take it off for the next cut.
Mo1, as mentioned, the weight per tire foot print is beyond my data access. As far as how I like the machine, it seems very well engineered and built. I had a bad / failed glow plug in the tier4 dpf causing some initial issues. Dealer found and fixed. Note , B3350 is just at 19 hours on the clock. I pushed my 6' bucket from my L39 through the snow with it and worked great and I was cozy inside.
Addition / correction. My b3350 is more like 3300lbs with fel ( no bucket_) , 60 " mmm and grass collection on rear.
/ Tractor weight vs. finish mowing #10
I have a CCY SX3100 i would say weighting in at about 2250 lbs. I remove the loader for mowing. It has r4 tires on it. Personally i would not want any bigger of a tractor for mowing. In some spots on my lawn that stays damp most of the time i end up leaving in prints of the tires. Any heavier i think i would leave ruts. If your property is high and dry you should be able to get away with a heavier unit. Only time will tell what works for you.If i left the loader on i would do alot more damage while turning.
/ Tractor weight vs. finish mowing #11
I recently posted about this same issue sort of. I was comparing john deere 2520 to a bobcat ct 225. The consensus was john deere if primarily mowing, and bobcat if primarily doing ground engaging work. I ended up splitting the difference on a new Branson 2400H. I felt it had good weight for my ground work, and still light enough for the mowing aspect. It weighs in at 1811 dry weight, plus the loader. I figure around 2400 lbs maybe?? I have 6.5 acres, split pretty evenly with woods/grass. I needed something small enough to maneuver the woods, but still big enough for ground work. After looking at the bobcat, I realized it was too big for me.
/ Tractor weight vs. finish mowing #12
Approximately 4,300lbs (not including mower)....no problems unless the ground is really wet, or I don't pay attention, and make really tight turn (like one tire nearly stopping). I have some R3s I'm thinking of trying ($200 for the set with wheels!) to see how they do when it's a bit wetter.
/ Tractor weight vs. finish mowing #13
I mow my place with my L5240 and a 72" RFM, if I have time or am not using it I take the loader off as it makes it easier to maneuver. I don't have any issues with rutting unless it is extremely wet. I just mowed Thursday evening after work after it had rained that morning and while I had to be careful making tight turns because of the wet ground, there was no rutting problems. If I had R3's instead of the R1's I don't think it would be any concern. My tractor weighs in about 5000 lbs with the loader and RFM on. While it is a big machine to do finish mowing it handles so many other larger chores with ease that I can do all I want with only one machine.
Here is a picture without the loader.
/ Tractor weight vs. finish mowing #14
Looking at a Dere 5505E for serious yard/clearing work, but want to finish mow as well. With R4 tires, is this thing too heavy for grass on sand (north central FL)?
/ Tractor weight vs. finish mowing #15
I finish mowed with my L3710 Kubota on R-4s but only in a 3 acre front yard where I wasn't concerned about some scraped ground I and bare spots in corners. This is on heavy clay soil which I believe is a lot harder to rip up than your sand. I think it all depends on the quality of cut you want. Everything around our house gets cut with our JD riding mower to get an improved look.
/ Tractor weight vs. finish mowing #16
On sandy ground I think a 5505 might leave some marking. Like MHarryE said, what type quality cut are you looking for?
/ Tractor weight vs. finish mowing #17
I am currently mulling over this same issue but will be mowing with a JD 5210 MFWD tractor with a self leveling loader attached I am searching for a set of r3's since the r1's I have are very sharp and leave pretty good impressions. my tractor is 53 HP with 47 on the PTO . currently trying to figure out weather I should get a large rear finish mower or a 6-8 ft flail . we live on a residential airport with a grass field and take turns mowing it my b7100 is broken currently but to small for the runway task
/ Tractor weight vs. finish mowing #18
Was at the dealer yesterday trying to make marks or ruts on his lawn with the Deere 5055. The R4s appear to distribute the weight very well; no ruts or marks. Obviously trying here to combine two inconsistent functions: finish mowing (for which a 20 something hp with a belly mower would be fine) and ground work, for which bigger power is needed. Also really like the A/C cab of the 5055e -- hot here in FL!
/ Tractor weight vs. finish mowing #19
For mowing a runway, I'd go with the widest mower you can manage. I help my neighbor with his runway a couple of times a year....he runs a 6' mower behind his tractor, and a 5' mower on a side tagalong, so he's getting 11ft per pass. I'll line up my 7.5' mower behind him, and we're getting 18ft per pass, and it still takes a while.
Flail mowers won't give you quite as perfect a cut as a finish mower, but would seem to be a good fit for what you're doing...I'm considering one for a couple of large areas I keep mowed, but aren't my actual lawn.
/ Tractor weight vs. finish mowing #20
Yes the widest without being to much for my tractor think 8 ft multi blade finish mower maybe a 7-8 ft flail not sure or how my tractor will handle either it seems to handle a 5ft tiller easily though... I have used my neighbors massey with a 6ft rears flail a couple times but not on my tractor would sure like to get a chance to see how it would run a 6 ft then I would have an idea if it would pull a 7 or 8
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2005 Volvo VNL Truck, VIN # 4V4N19TGX5N374968 (A61165)
2005 Volvo VNL...
UNUSED ATS DJ2200 ELE. LIFTING MOTOR (A62131)
UNUSED ATS DJ2200...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2018 Freightliner M2 106 Single Axle Dump Truck, VIN # 1FVACXFC4JHJM9637 (A61165)
2018 Freightliner...
UNUSED WOLVERINE SB66-66" ROCK BKT (A62131)
UNUSED WOLVERINE...
