Lumberjacks! I need advicePlease!
/ Lumberjacks! I need advicePlease! #1
garacuda
Elizabethtown, KY
John Deere LX255 - T0-30 - John Deere 4200 w/FEL
Years ago when this wasn't part of my back yard, this old Pine tree held targets for all sorts of firearms practice. Now I need to remove it so it won't someday fall on my new carport that's going in next to it. The side to the left is dead........and that's the direction it has to fall, or it hits the house and my wife gets mad, or it hits a fence and my neighbor gets mad. I can deal with the neighbor.
Question to you more experienced lumberjacks; If I tie a cable about 15' up on the tree and put tension on it in the direction I want it to fall (pulling with tractor) will the rotted/dead part at the base cause it to have a mind of it's own as I saw through the back (solid) side? Or will the pulling override any wild tendencies it may cause by being dead? The double tree behind it goes next, but I'm not too concerned about dropping it straight, it can only reach the fence, but I think I can convince it not to.
All thoughts and ideas are welcome.
Well, I can't seem to get the photos to load in the post. I will try it again from work and see what happens. The dead portion is at least half across and just as deep. The base is maybe 14"-16" .
Thanks for any input.........photos in the morn, I hope.
/ Lumberjacks! I need advicePlease! #2
the higher up in the tree, the better,
but use caution if the leverage is not adequate, it can pull the tractor or truck all over the place, (one is better to use a 4 wheel or front wheel drive, as when one puts tension on the chain or cable it start to lift the car/truck/ tractor rear off the ground,
I like a heavy truck with an automatic transmission as one can put tension on the line and not be slipping the clutch, and make sure the line is longer than the tree so the tree does not come down on the pulling unit, some times operating in reverse is better with a two wheel drive, (two factors, one can see the working progress, and the pulling wheels do not loss traction as tension is increased, with the high point of connection, in the tree.
/ Lumberjacks! I need advicePlease! #3
Really need pics and a sketch of the boundaries. Are you dropping a 20' pine 15
from the house or a 100' pine 15' form the house?
When I've done that type of work (50' maple w/ lot's of danger areas to hit) I got up the tree in a ladder and topped and limbed it partially, greatly reducing the danger. Still hit a chainlink fence.
Other trees will grab a limb and twist a falling tree around.
/edit - and when you write "the base" do you mean the diameter at the ground or at chest height?
/ Lumberjacks! I need advicePlease! #4
The rotten section can change how the tree hinges as it begins to fall, making it tend to go sideways.
The cable tension should continue to pull the tree as it falls, not relax as soon as the tree moves(as if it has a fixed anchor.)
If it is rotten enough and your truck or tractor is strong enough, maybe try to pull it over instead of sawing, to better control the direction. Steady pull, don't jerk.
Bruce
/ Lumberjacks! I need advicePlease! #5
My 2 cents about using cable to direct fall: Once you then start cutting and the tree moves, the cable goes slack and gravity then takes over and tree can the fall up to 90 degrees away from direction of "pull". So, you must keep applying tension as you cut the tree to keep slack out of line. BUT, too much tension and you will barberchair the tree, (Look it up on youtube. This is a very bad thing.) Not notching the front side will also cause a barberchair. You will definitely want to put a notch on it. Avoid using dead wood as your holding wood /hinge.
Couple ways to lesson the chances of barberchair caused by deadwood or a cable's pulling up high on the tree is to strap a chain around the trunk right above where your cutting to hold the trunk together instead of splitting. Or if your comfortable, research a Plunge Cut that leaves a holding strap.
/ Lumberjacks! I need advicePlease! #6
Good Luck. My Experience has been with some large (80 foot) Oaks and pulling with a 30 HP 4WD 2000 Lb. tractor. You can pretty much get them to go away from where you don't want them to go but you need to consider what they might hit that will alter their course. I used 2" steel cables and 4" fiber lift straps. Notched the fall side then sawed from the opposite side. If the tree is half dead, your bets are off with the possible exception of pine. Some Pines, depending on species, can easily be pushed over with a front end loader because some don't root deep.
/ Lumberjacks! I need advicePlease! #7
If there is risk, My experience is to truss that tree like a chrismas turkey! Don't rely solely on a single controling cable. Attach pivot lines that are tensioned with come alongs or chain falls to solid fixed objects. The "pulling line" is an added member.
I dropped a pretty good sized maple out front of the house this winter. about 30 inches at the butt ;-) 90 feet tall and "field grown" for the past 30 years, so it was full of growth.
The felling direction was opposite the big weight up high. the felling direction was also away from the house which was only about 35 feet ;-)
I had two chains to nearby trees as "keepers" and "tensioners" with 1 ton cable come a longs to give the tension. Then the 1/2 inch cable was secured up as high as I could reach on a 25 foot extension ladder. This to the 2 ton chain ratchet pull that was around behind a nearby hemlock with the cable redirected through a snatch block. I pulled that ratchet handle till I thought the tree was going to come over without a saw cut!
The box cut went fine, I always plunge the back cut on the big stuff. The HINGE WENT TO NEARLY NOTHING before I heard any sound.
At first cracking of wood, I set down the saw and lifted the muffs. Earily quiet! No signal that all those tons of maple were getting ready to lay down for a rest.
I ran over to the chain ratchet and started hauling in chain. I could see the top coming my way, but it was slow. I was certainly trying to move up stream! Sweating bullets! Still not a sound. Usually there is a stream of cracks and pops to let me know that things are going my way. Not this one.
A few more tugs on the ratchet, and a couple on the come a longs resulted in a great snap at the butt. The tree started coming my way. I ducked for cover around the hemlock, and it was a good thing I did. The maple dropped RIGHT ON TARGET, but it knocked off some good sized limbs high up the hemlock as it passed by. Good sized ones too, as in 4 inch stuff. Those limbs broke off and fell down like spears and worse. Quite a racket all in all! (Though I am positive the falling and breaking and crashing and smashing would have been entirely silent had I not been around to hear ;-)
So, All I'm saying is to double up your security. The "Belt and Braces approach is often just enough!
/ Lumberjacks! I need advicePlease! #8
I need to see the tree. Work on photos.
img commands in brackets work as well as attachments from your local computer.
/ Lumberjacks! I need advicePlease! #9
I could snap a photo of the stump, but the "tree" is all worked up to fire wood and in the shed '-)
All except the small limb wood and the uglies, still in a rough stack where it fell.
(Couldn't have got the first 20 feet of rounds on the splitter without the loader, even the halves were too heavy !)
/ Lumberjacks! I need advicePlease! #10
The best advice I can offer is hire an insured professional to drop it then you can spend your time to cut it up afterwards instead of repairing the house or fence. It will be money well spent. Speaking from experience, unfortunately.
/ Lumberjacks! I need advicePlease! #15
<snip> but it knocked off some good sized limbs high up the hemlock as it passed by. Good sized ones too, as in 4 inch stuff. Those limbs broke off and fell down like spears and worse. <snip>
Like I wrote, other trees will reach out and try to save their falling comrade! :)
My son got bids for falling a large (~ 3' DBH) maple next to our house. The LOWEST was about $2K, 2 others were about $5K. That's my retirement income for a month. I plan on buying equipment. I've already got the saws (35CC for upper works, 60CC for a little lower, two 90CC (660's) for bucking and a 120CC (088) for cutting the base. We should be able to do it. If I didn't already have the saws and some exeprience it would be better to just pay thru the nose.
Significant risk' Wear your PPE's, take it easy and watch out for the harsh feel of metal on the chain.
Remember pictures like this:
chaps are worth it.
/ Lumberjacks! I need advicePlease! #16
If you cannot put a proper notch and back cut to control the direction of fall, then you probably should call a pro. I'd be glad to offer advice with some pictures, but I normally see questions like this here and think its a sign the poster should call a pro. If you do need to cable the tree, it takes a lot of experience and sense to do right, otherwise you can make the situation WORSE.
Okay, the pics did fine on my work PC. My thoughts are that I will be notching the dead side out on the same side I will be pulling from, leaving me to cut live tree to fell it. It's just goofy looking enough to make me want to ask for thoughts from others who have been there-done that. I've dropped a lot of trees, and knocking on wood, so far no problems.......but, I'm ever cautious, especially when something looks..........funky. The "barberchair" was a new one on me however, I can see it happening easily when a tree is being pulled and the saw stops before cutting far enough. I'm thinking I'll notch the crappy side with an older chain because I'm sure I'll hit some lead, then use a fresh chain and a full tank to make the back cut. If you can, visualize me trying to drop it in the opening between the trailer and the wood stake in the photo. (trailer will be moved)
I've got about a 35' wide window between the house and the neighbors fence to drop this bugger in and it's not very wide at the top. I think my shooting into it years ago stunted the limb growth. ;-) I'm not worried enough to call a "pro", or some may say not smart enough to, but I would like some thoughts now that I finally got some pictures to load.
Thanks to all so far, it's all good sensible advise.
/ Lumberjacks! I need advicePlease! #18
wow -- that tree is gone.... its mostly hollow. I wouldnt worry about barberchairing much.. nothing in it to split up the middle. I see it already has a lean and its gonna go in that direction. Do you have a nearby tree? If so why not hook a cable to the base of tree for a tension point and put other end of cable high up in dead tree far up as possible. tension cable lightly. make your front cut shallow as its hollow tree and then tension cable as much you dare, but dont over do it. then do your back cut.
/ Lumberjacks! I need advicePlease! #19
It can happen at any time on any tree. Adding tension by pulling before completing your cuts and trees with a lot of lean dramatically increases the chances. Good idea to have the rope / cable hooked up and ready to pull before starting your cuts, but no tension until your clear of the danger zone.
/ Lumberjacks! I need advicePlease! #20
Yeesh! That dead rotten wood looks unpredictable.
Though it's a trade-off and makes it harder to get away from the tree if things go bad, it would lessen the chances of things going bad if you could make the cut up higher where the tree is good and not rely on rotted wood for the holding wood/hinge. You don't want to cut through the hinge when directing a tree (or anytime) and want it to be reliable to steer the tree down.
Again, put a safety strap or chain in a belt fashion around the trunk above where you're making the hold the trunk together from splitting/barber chairing.
Falling a tree gone wrong (Barber chair) - YouTube
