JD 2720 Question
/ JD 2720 Question #1
stablerock
Morgantown, WV
JD 2720
Hi all, I'm new to the forum and have several questions that hopefully someone will have the answers to.
Not sure what it's called....but on a JD 2720 and maybe other similar models as well, there is an adjustment knob directly in the middle between your legs on the floor.
I know its some sort of hydraulic adjustment....and can be adjusted from "fast to slow" etc., but unsure exactly what it's function is and how it affects hydraulic performance.
I think it slows down the hydraulics some so your attachments are not so quick and jerky, but does it also reduce the hydraulics power ?
Can it be adjusted to make the 46 backhoe attachment more smooth...and less fast and jerky, without reducing the digging power/force ?
I'm considering a used 2720 and would like some more info before I pull the trigger.
Thanks Jeff
/ JD 2720 Question #3
Thanks Jeff
Jeff it only slows the lift and fall of the three point hitch so you don't slam your three point attachments like Bush Hogs on the ground . very gentle turns allows you to ease them down . Hope this answers your question
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
