Raber
I'd like to share my experience as owner of a year model 2013 Kubota GR2120, bought in June 2013. It now has 32 hours on it.
It replaced a year model 2012 Kubota T2080 that proved ill suited to mow the sloped area that surrounds my house.
The 2080 would go up, but just slide down, due to its front end overweight and rear end only braking capability, a rather frightening experience. For the rest, it was a fine piece of machinery.
When shopping for replacement, I considered the John Deere 500X (2WD, locked differential capability) in a much lower price range. Discarded it for dealer aloofness and after consulting many forums and reviews on both machines. Learned about the transmission flaws of earlier Kubota G series models, but also noted that the company solved the problems (for earlier clients) and on newer models.
Also got false information from sellers on the Net, while trying to buy used. Beware.
The GR2120 mows well, is easy to control, goes up and down slopes at a steady pace and turns on a dime. Fuel consumption (diesel) is low, unlike what is reported in forums about the JD500X, considered to be a guzzler. It easily tow its own weight (800 pounds without the mower) on a Swisher 16cf trailer full of dirt or stovewood. "Glide steer" prevents turf damage and 4WD provides for lots of traction. Seat is comfortable and controls are handy and well designed. The whole machine is well built, sturdy and harbor no cheap parts. Some are complaining about the plastic hood (bonnet); I see it as an advantage, since it will not carve in like metal under inevitable light shocks. Mounting and dismounting of the mower proved straightforward and easy.
As far as maintenance is concerned, grease zerks are easely accessed to, as well as oiling spots. I have not yet changed oil or filters, so I have no comment to provide.
The Kubota GR2120's only drawback is limited capability to back up slopes. It just stops moving. Probably due to a "weak hydro" as some have written about. So, if you need to back up slopes, use attachments requiring significant hydro power or haul a larger weight cargo, consider a Kubota Bx instead. But the price tag will be steeper, as well as the weight you carry around your lawn; from 960 pounds to over 1,500. In my case, with the specific requirements of my property, the GR2120 is just working out fine.
Hope this will be helpful when time comes for choosing the machine that suit your needs.
