Hopefully Simple Fix
/ Hopefully Simple Fix #1
Bowhunter828
Hayesville, Nc
Ford 3930 and Ford 1210
New to the forum but have been reading on here along time. I have a Ford 1210 4x4 with FEL. When I take the FEL off the three point hitch hydraulics do not work. Put FEL back on everything goes back to working fine. I have looked for a lever to redirect hydraulic flow. I have checked fluid levels. I have come to a dead end. Any suggestions? Thanks
/ Hopefully Simple Fix #2
New to the forum but have been reading on here along time. I have a Ford 1210 4x4 with FEL. When I take the FEL off the three point hitch hydrolics do not work. Put FEL back on everything goes back to working fine. I have looked for a lever to redirect hydrolic flow. I have checked fluid levels. I have come to a dead end. Any suggestions? Thanks
I take it that the FEL valve assembly stays with the loader and does not stay on the tractor on this model?. there has to be either a hose to connect the hydraulic flow back towards the 3pt (bypass hose) or a large screw on the hydraulic distribution block to turn to direct the flow the other direction. On more modern machines where the FEL valve assembly stays with the tractor this is automatically accomplished by the Power Beyond port on the valve assembly, So you normally have 3 hoses coming from the distribution block to the FEL valve. 1: Flow from the pump. 2: Return to tank 3: Power beyond. The power beyond powers everything downstream including the 3PT.
If you could post a picture of the hydraulic distribution block and the loader valve assembly, perhaps we could help figure this out. Also I take it you have never taken the loader off before? And this is not something broken but a matter of not knowing how to proceed? please advise.
/ Hopefully Simple Fix #3
You did not say that the loader valve was left on the tractor.
If it was left on, there should be no problem as the fluid passes through the loader valve and on to the 3pt.
If the loader arms was powered by two sets of QD, there is no problem as the fluid is blocked even if you did use the lever.
If the loader and valve was disconnected, then you have a pump hose and what was the PB hose going back to the 3pt which should be connected together, and then things should work. Also plug the return hose from the loader valve.
My hyd block has a switch to change the flow path. I just plug excess ports.
Yes , first time taking it off. I don't think there is a pump problem just an operator error. I may need to make up a line for return ,but why? Thanks for your help.
/ Hopefully Simple Fix #5
Just find your pump flow on the hyd blk and run that back to the 3pt.
The loader controls came off with the quick disconnect. I have looked for a valve but do not see one. I'm sure your on the right track with needing to connect a return line. In the pictures it shows all the lines in and out. I do not use all of them. The dealer installed them in case I wanted a wood splitter and wanted to leave the FEL on. Thanks to everyone.
/ Hopefully Simple Fix #7
The dealer did that plumbing? If it was mine I would make a bracket and move the loader valve to stay with tractor when taking off.
/ Hopefully Simple Fix #8
Where is the hose going that is still attached?
The water pipe plumbing has to be the return as you don't use water pipe in hyd.
The QD that the dealer has for the wood splitter, where is it?
/ Hopefully Simple Fix #9
There should be a screw control just under the first connection on the hydraulic block.. turn it so that it is at a 45 degree angle like this picture.
/ Hopefully Simple Fix #10
Isn't Galvanized water pipe fittings good for 300 PSI..? I bet even that little tractor is 1500 PSI in the hydraulic system at least maybe more.
/ Hopefully Simple Fix #11
/ Hopefully Simple Fix #12
In your 1st picture, what is that little hand telling you? That block seems to me is high pressure in and out of it.
/ Hopefully Simple Fix #13
The hand symbol appears to point to the manual. Otherwise telling the operator to read something about that hyd block.
I would also add that the lines with water pipe fittings are probably the return lines especially using multiple connections. You don't tee pressure lines.
There are lots of things that one can do if one knows the hyd system.
/ Hopefully Simple Fix #14
I wonder if he ever found the screw slot.?
On the back side of the hydraulic block there is two pins which indicate there is another position that might redirect. It is very hard to see. You have to crawl under the tractor and it is still hard to see as it is close to the engine block, but upon turning to the other position I now have lift to the rear. If I had a manual it probably would have told me this. Thanks to all who responded. Everyone helped get this problem solved. Seems I keep having the same problem, I'm too narrow between the ears. Thanks again
/ Hopefully Simple Fix #16
Seems that removing the FEL interrupts the fluid flow, probably a Power beyond connection to the 3 PT. Time to get some manuals on your tractor and quit guessing. My BX has the FEL valve permanent on the tractor so the flow is not interrupted as the valve continues the PB circuit. Unless a major change has been done to the hydraulics the Owners manual may give you a clue. You may need the shop service manual to trace out the system. Maybe someone on here has the same tractor and can look it up.
Ron
/ Hopefully Simple Fix #17
Ron
He got it figured out in post 15
6' STACKING RAKE (A64276)
6' STACKING RAKE...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
1999 New Holland 688 Round Baler (A63688)
1999 New Holland...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
