tach meter
/ tach meter #1
slammer3364
Jinma 284
Had my Jinma 28 to the mechanic,say (he called it a tach sensor).Screws into engine block, must read the fly wheel. Is this the correct name of part?
/ tach meter #2
Technically it's a reluctor but the slang terms are "mag pickup" or "tooth counter".
/ tach meter
Thanks Bob appreciate it going to see if I can order part Mon.
/ tach meter #5
I kinda hopping on this thread with a little different question on a JM 354. My tach consistently reads at High Rpm 1600. I'm not sure whether the fuel pump is just not getting the engine to rev up (2200) or my tachometer has a bad component? Any suggestions? bjr
/ tach meter #6
/ tach meter #7
You can verify the tachometer's accuracy with a photo-tach, if you have one. Got mine at Harbor Freight.
/ tach meter #8
I just bought a 2004 JM284LE, and my tachometer is not functioning. Is it safe to assume that this is function of a sensor and not a cable?
Thanks J
/ tach meter #10
Tommy
Thanks again, I know who I will go to for parts.. This is a bit off topic, and I asked this question in a different thread. I am leaking hydrolic oil out of the vented filler plug, this seems to only be a problem when going up a steep incline. Is this symptomatic of anything other than gravity...?
Thanks ..J
/ tach meter #11
/ tach meter #12
Before spending any money on dripping hydraulic fluid, you should actually confirm the cause. Most common cause is simple over-filling. Not sure how many lines you have on your dipstick, but mine had one. I treated that as the "full" line. With the dipstick set on the hole (not screwed back in). I'd unscrew, remove, wipe, insert, remove, check. Never added hydraulic fluid unless/until the dipstick came out dry. Also - since good usable hydraulic fluid should be clear as water - it's kinda hard to see on the dipstick. So I'd lay the stick horizontal on a rag or paper towel, and use how much transferred to the cloth/paper to determine how much was on the stick.
Another reason for fluid dripping down the back is a hydraulic leak on the suction side. That will typically foam up the fluid, especially if it's wet/dirty. In those cases what you're seeing come out the vent is the hydraulic "foam" that's turned back to liquid in the open air. That said - if you've got the correct level of clean fluid in the sump - it's still possible for a little to run out on severe up slopes.
//greg//
/ tach meter #13
Greg
This is definitely leaking out of the vent hole in the filler plug, I live in the montains of Oregon and have a lot of very steep inclines.
/ tach meter #14
That leakage is normal when going up steep inclines if the reservoir is full. You can either extend the breather or relocate it to solve the problem.
/ tach meter #15
Greg
Then - assuming that you've got clean fluid at the correct fill level - a breather extension would be appropriate. Oh, one other thing; always lower any hydraulic implement (front loader, rear lift, etc) before shutting down the engine. That keeps the fluid inside the cylinders. If you wait to until after shutting down the engine, the fluid returns - and subsequently overfills - the hydraulic reservoir. Like I said originally, you have to first determine the cause of the spillage, before opening your wallet.
//greg//
/ tach meter #16
Greg
At my age I am pretty careful about opening my wallet. I see you are a retired sailor, I spent a quarter of the cold war in the North Atlantic Submarine fleet.
And back to the original topic, I tracked down my malfunctioning tach, to a dirty connector.
2012 Ford Explorer SUV (A61574)
2012 Ford Explorer...
LandHonor Mini Auger (A62183)
LandHonor Mini...
Deer Statue (A62183)
John Deere 4240 w/ Buhler 695 Front End Loader (A64047)
John Deere 4240 w/...
2013 John Deere 5075E (A62180)
2013 John Deere...
Pig Statue (A62183)
Pig Statue (A62183)
