scattleberry
Hi,
I've got a 42" chain driven tiller for my tractor. I'm trying to remove the upper cog that is on the shaft that connects to the PTO. The previous owner had replaced the stock cog with a smaller one so the tiller could be operated at 1000 rpm PTO speed. I'd like to replace the existing cog with the larger stock one so that I can operate the tiller at 540 rpm.
My problem is removing the cog. I removed the clamp ring, but I can't get a puller on the cog because the chain runs around it right now, and the puller would have to engage the chain, which I don't think is a good idea. I can't break the chain, because the link with the removable pin slides back and hits the back of the case before it disengages the link. There isn't enough play in the chain to move it forward so I can move the pin far enough back to break the link.
Any clever ideas? Right now I've got penetrating oil on the shaft at the cog. Should I forgo the puller and just use a prybar to try to lever out cog, turning the cog (by turning the pto shaft) as I apply the pressure?
I can't help but think there is an easy solution to this, but I sure can't see it!
thanks,
chris
thanks,
chris
