rear lug nut torque
/ rear lug nut torque #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Can someone tell me the torque settings of the rear tire lug nuts?
I have a ck35
/ rear lug nut torque #2
According to my owners manual on page 8-3 in the lower right hand corner it says 50lb-ft and that is for the ck25/27/30/35 The same owners manual covers all 4 models.
Retorque after a couple 100 yards
/ rear lug nut torque #3
I would be very careful torqueing wheel studs/nuts; thought I should check mine with a torque wrench after delivery and ended up stripping a couple, very easy to do. Now I use a half inch ratchet/socket and snug them up like I would an automotive wheel
Thanks for the info!
/ rear lug nut torque #5
I have a John Deere the same size and weight and uses the same size tires. My lug bolt torque is 140 lb/ft. I do not think I had a car that had a lug bolt torque that low. We are talking about a Kiota CK35 tractor which weighs about 3,100 pounds and has 34 HP? The picture shows the same sort of lug bolt pattern front and rear as my JD.
Looking at a torque chart in my owners manual a grade 10.9 metric bolt in 10 mm would use 55 lb-ft.
Plenty of torque charts available with a Bing or Google search. Metric Bolt Torque Chart
/ rear lug nut torque #6
My DK35se calls for 160 ft lbs on the rear lug nuts. I don't think 50 ft lbs is any where near enough on the Ck35
/ rear lug nut torque #7
I think 50 ft-lb is for the fronts. I believe the rears are supposed to be about 200 ft-lb. Look at your owners' manual. If you don't have one, get one.
/ rear lug nut torque #8
I just moved the rears on my M4700 so I could get it on the trailer. They (/edit - the manual ) called for about 200 or 225 lbs. I didn't have a torque wrench that went above 140. So I put a 210 lb weight (my son) on the end of a foot long wrench.
/ rear lug nut torque #9
I took that info right out of the owners manual. I don't agree with it, but I did take it from the owners' Manual. Here is the page:
and here is the front of the owners manual....See where it says CK25/CK27/CK30/CK35
/ rear lug nut torque #10
Sounds like each make and model is different. When in doubt, I follow the manufactures specs. My L3400 is 160#. Seems high but that's what I go them torqued at.
/ rear lug nut torque #11
No matter what torque I would use, and I might be all wet here and adding where I shouldn't add, but I would find out the correct torque and time intervals between torquing and follow the guidelines through a few heavy uses, keeping an eye on the lug-nuts. I heard new paint makes re-torquing a must.
After I would feel comfortable with them, I would take all the nuts or bolts off and put blue lok-tite on them and then re-torque them again. Once lok-tite is on they won't vibrate off.
On my 45 HP tractor I torqued for the first 10 hours or so and then I forgot to pay attention until I broke a valve stem off, then I noticed all the nuts were loose, enough to where I got all new lug-bolts. I lok-tited them and for the next 350 hours, never had a problem and I feel secure.
/ rear lug nut torque #12
The torque you are referring to is when you use the offset plates on the rear rims. The picture shows a variety of positions. By the way my JD manual shows 160 lb-ft for the offset bolts. My offset bolts and nuts are the same size as the lug bolts. What does the next page say about lug bolt torque or maybe somewhere else in the manual?
/ rear lug nut torque #13
Well, this is one more data point where I'm not impressed with the accuracy of Kioti's US documentation.
Here is a scan from a 2007 CK service manual:
For comparison, the torques for my DK45 are 137 ft-lb front and 235 ft-lb rear, according to the owners' manual. By the way, I have two different editions of the owners manual for my tractor and there are several places where they disagree. Personally, I'd be inclined to err a little on the low side rather than risk snapping off a stud.
Supplemental: I just looked and saw you have a 2012 model, which must be an SE configuration. So the manual page I posted doesn't apply. Still, it must be more than 50 ft-lb.
/ rear lug nut torque #14
My 2004 CK30hst manual shows 66.5 ft/lbs for the fronts and 166.3 ft/lbs for the rear.
/ rear lug nut torque #15
I just tighten by feel if using a lug wrench. When they feel tight, I stop. Never broke one or had one loosen off.
Now I just use my impact gun and tighten them snug then let it hammer for just a second watching the socket. When it quits turning, its tight. I have a 1/2" drive for the front wheels and a 3/4" drive one for the rear using max of 140 PSI air to drive it.
I'm totally confused about the offset plates. What are they?
Have we come to any conclusion on the rear lug torque values?
/ rear lug nut torque #18
The next page is all about ballast.
EURIKA! I found it!
Under 'Periodic Service; REARS 166.3 lb/ft
FRONT 66.5 lb/ft
I will change it in the other part of my manual.
/ rear lug nut torque #19
50 ftlb has gotta be wrong; even for fronts. I go 80 on the front lugs of the BX1500.
larry
/ rear lug nut torque #20
Don't you guys take this the wrong way, because I don't mind jumping in here to help someone out...but....For about the same cost as 2.5 gallons of fuel...you can own a repair/service manual. Then you won't have to wait a day or two for the correct answer to your questions to pop up......Hill Billy Bob
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2019 F-550 Bucket Truck (A63689)
2019 F-550 Bucket...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
