Operating with the park brake on
   / Operating with the park brake on #21
My 18-year-old JD has a big flashing red light when the brake is on. Isn't this common?
Terry
Mine doesnt flash, but it is a pretty good sized red light. But many of the economy tractors do not have anything to indicate the brake is on. On Hydrostat models you can usually tell because the hydro whine is much worse with the brake on. With any tractor you should be able to tell, but if you are in a hurry or distracted you might not notice.
   / Operating with the park brake on #22
If you set the brake correctly, meaning hard enough so that the tractor wont move, then when you try to move it with the brake engaged, it is going to stall the engine or if HST just not move. No more driving with the brake partially on.
I have a light on my LS and still forget to release the brake, but when the engine starts to stall, I then remember. MY Kubota B26 doesn't have anything, but same thing, when brakes are set properly it wont move.
The only thing I have driven with the brake on is my RTV when my brother in law pulled the brake partially. I hardly ever set the brake on it but when I do it is hard set. I drove it about 200 feet and when I started to climb a hill it seemed to have no power, more pedal and more stalling. The further I drove the hotter the brake got and the more drag it produced till I finally realized the brake was lightly engaged. Brother in law has a JD Gator and must set the brake each time he stops to keep it in place.
   / Operating with the park brake on #23
My farm is as level as a pancake, so brakes are usually an unnecessary option. On my JD 4120 (5 of 9 tractors with a parking brake), there is a big red light of the dash, and no mistaking that the brake is set because then tractor will only move then in a real low gear and high RPM. On another little one with a parking brake (troy-built bronco), it does not work at all. In fact the only way
I can get that one to stop at all is when it is in reverse, and I engage the mower. A screwy (handy for me) safety feature that I capitalize on when storing, by backing it into its spot. That kills the motor and stops the wheels as good as a "real" brake.
Other tractors brake situations are: 1951, Ford 8n that right side still works good, but no left. I work with that by only working fields with hard right turns. There is a big difference between one brake and no brakes making that tractor still reasonably safe on hills or the road. Allis Chalmers "C" that both "original" 1941 brakes still work perfectly on. This makes that old trike an ancient "zero turn", real handy for cultivating or maneuvering in the woods while dragging logs. Farmall Cub whose brakes are completely worn, but no real need for any. I can always drop the cultivators to make it stop or hold it in position. Wheel Horse, 1980 something, 12 hp, gear, riding mower on which the parking brake still work perfectly. A second, 10 hp Wheel Horse, same year, on which the parking brake still works but the Kohler engine is pretty much shot. 1980 something JD 770 with non-working parking brake, but regular brakes still work so-so (probably because the prior owner did what you did). And lastly, an old 1951 JD "M", on which the brakes are completely worn out from many years of normal use.
From all of these, I have seen that with normal, proper use, a parking brake should last for many years. A little bit of misuse will take out or damage the tractor's brakes in short order. Obviously it is best to be careful here, especially when you have a tractor, like yours, that will operate almost normally with the brake set, and give you no clear indication that it is on. The good news is, as long as your place is fairly level, brakes are no big deal. That especially true if it is gear-drive, meaning you can always hold position by shutting down engine while in any gear.
   / Operating with the park brake on #24
After adding a brake light I got in the habit of always using the PB, it has cut down the number of times I try to drive off with it on.
L2800 w/FEL - 72" Land Pride rake
   / Operating with the park brake on #25
As I have a hst, so I just need turning brakes & emergency brakes. I just leave my brakes unpinned. The ebrake catch only grabs the left brake, so if I leave it on I figure it our pretty quick when I'm driving in circles or sideways. Left it on a few times when I had them pinned.
   / Operating with the park brake on #26
If you set the brake correctly, meaning hard enough so that the tractor wont move, then when you try to move it with the brake engaged, it is going to stall the engine .
You must live inthe worls of baby/wussy tractors? ;)
If my tractor engine can't power thru brakes.. it needs rebuilding.
I've yet to drive a real ag ( not heavy equipment ) tractor that could NOT drive thru full brakes set
Heck.. that's how I test a machine BEFORE I buy it. see how much the brakes drag the engine / see what the governor does.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1R COLE PLANTER (A52708)
1R COLE PLANTER...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
CASE IH 8R PLANTER (A52708)
CASE IH 8R PLANTER...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
