Any help from Kioti on broken subframe
/ Any help from Kioti on broken subframe #1
chubby
Georgetown, De
Kioti DK50SE hst w/hoe & John Deere 3720 hst cab & John Deere 3120 hst w/375 hoe
11/11/11 purchased DK50 loader and hoe. Today subframe cracked on both sides at the the location where frame starts to stack. Now I read this site often and have read where other subframes where rusty and that was said to be the reason. My is not rusty and every 100hrs I check or torque all loader and hoe bolts. I have used the hoe just as I have the two other hoes I have owned. Tractor has 660 hrs and probably 300 hrs is on the hoe. Backhoe warranty says 1 year, but a broken subframe where this is cracked is poor design. My last 2 hoes had 0 issues. But both also used the 3pt top link. I know Kioti says NO to the top link, but this is crazy. Any stories on how to get some assistance from Kioti or where to buy a new subframe a good price would be great. Thanks
/ Any help from Kioti on broken subframe #2
have someone weld up the cracks
/ Any help from Kioti on broken subframe #3
I would think repair what u have would be best then u can reinforce stress areas as needed. I'm thinking that if u broke a subframe then u dodged a bullet vrs. Tractor repair.
/ Any help from Kioti on broken subframe #4
I understand your frustration but unfortunately you're over the one year. My KB2375 on my CK30hst is 9 years old and still no problems but it is also not as strong as yours. I believe you have the KB2485. My bh will move the tractor around when digging hard stuff but my tractor is also lighter than yours which may keep some of the stress off the mounting frame by the tractor moving. You could buy another subframe from a dealer if you wanted but I would probably just reinforce and weld what you have. I haven't seen any of the members with the KB2475 posting that they broke their subframe so you may just have received a bad one and a new one might hold up better.
Emailed pictures of both sides of frame, one side is split with 1/8 in other with 3/8 in, to dealer and he forwarded to Kioti rep. So we will see what happens. Separted hoe from subframe and took frame to a machine shop. Cracks can't be welded. Tech said this was bound to fail. And at the place that it failed. Left with them to reinforce top and side and other ideas they come up with. Hope all is completed by Monday pm. Maybe Kioti will help!
/ Any help from Kioti on broken subframe #6
I have never seen any crack that cant be welded in plain carbon steel when done properly. I would take it to someone who knows a bit more about welding. I would drill a hole at the end of the crack to stop it from running then double bevel it so I could get full penetration weld, then weld it up with 7018. After welding the original steel, I would put on some doubler plates on the areas of stress and weld them solid.
/ Any help from Kioti on broken subframe #7
I agree. "It can't be welded" really means "I don't want to fix it and be responsible if I don't do it right."
/ Any help from Kioti on broken subframe #8
It would be nice to see some pictures of the breaks in the frame or the repairs.
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
100 Gal L Fuel tank (A65643)
100 Gal L Fuel...
